New Mod Idea
Old Jul 17, 2002 | 03:28 PM
Foglght's Avatar
New Mod Idea
well i did some thinking. How bout this! the 2k maxes may have a different fuel injector and mass air flow sensor than the 3.5 2k2. I would imagine that the hookups are the same. If us 2k-2k1 owners got a bigger maf and bigger injectors................whooo hooo more power. And suck an easy bolt on installation. I looked the the injectors and they are cake to remove and re-install.
Whats everybody's opinion
cya
ryan
Old Jul 17, 2002 | 03:31 PM
NYC2SD's Avatar
I think the power from the 2K2 is coming from the bigger displacement engine, not the injectors. Not such an easy mod (unless you have a cylinder boring machine)
Old Jul 17, 2002 | 03:34 PM
Foglght's Avatar
well now with bigger displacement comes more need for air. probably gonna need more fuel too. I am going to check out the part numbers, and see if the connectors match.
time to visit my local crappy nissan dealer. They all suck around here
Old Jul 17, 2002 | 03:42 PM
MichaelAE's Avatar
Now if that were true, then the Pathfinder, QX4, Altima, Maxima, 350Z, I35, and G35 would all deliver the same power. There are certainly other components to the power delivery and, although I'm not sure Foglight has found one, it is probably worth looking into it. Similar to how some VQ35 Maxi owners are investigating part swaps with the G35.
Old Jul 17, 2002 | 05:26 PM
MaxPower2K2's Avatar
you will have to reprogram your comp too!
Old Jul 17, 2002 | 07:20 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
the maf size is the same and the hookup is different.
Old Jul 17, 2002 | 08:11 PM
woosh's Avatar
The most likely thing
you'll get, is to see ur award winning v6 go *BOOM*.
I don't think its that simple. If the sensor work within the same voltage range then no change. If it provides different voltage ranges you'll have one confused computer and possibly *BOOM*
turbo dreams
woosh
Old Jul 18, 2002 | 11:08 AM
Foglght's Avatar
Re: The most likely thing
maf sensors run on a basic universal voltage system for a particular maker. but i just read that the hookup is different and it is the same size. It could be calibrated differently. Did this operation with fords before on the 2.5 contour motors, but not sure how it would work out on the nissans.
Old Jul 18, 2002 | 01:27 PM
spaaz14's Avatar
Yeah, it might be a good idea to let your computer know about this.
Old Jul 18, 2002 | 01:48 PM
MaximaMan77's Avatar
I don't know about the 00&01 but my 99's MAF was considerably smaller (1/2" in dia.) than my 02. I know this from my Stealen intakes, I had both at the same time.
Old Jul 18, 2002 | 01:55 PM
motectransam's Avatar
I'd be really careful about swapping in larger 2k2 injectors w/o a ECU remap. n cold-start up and maybe WOT you'll run too rich and probably cause long-term problems not to mention run slower from running too fat.
~motectransam
-Read High Performance Pontiac 10/1997: dad's 100% stock 1996 Bonneville SLE S/C runs 14.525 at 94.1 mph with 2.09 60' on Goodyear Eagle GAs and full tank Exxon 93 in 60 deg. F air. Best mph pump gas: 94.7 mph (41 deg. F). Best 60': 2.085 with Hoosier autocross radials. Best mph with propylene oxide/race fuel: 96.2 mph.
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
gigabyte
Jan 6, 2017 06:05 PM
sliptap
Sep 30, 2015 05:57 AM
zmcneely13
Sep 26, 2015 02:26 PM
