Mandrel Budget Y-pipe- annoying noise fixed!
Maxima.org Sponsor and Donating Maxima.org Member
My mandrel-bent Budget Y-pipe was making an annoying vintage VW Beetle type noise, with a bees in a can noise at high speeds (Yes, my pipe made 2 distinct annoying noises
). The noise was sourced to the unlined flex joint (aka flex section) Budget uses.
The noise was so obnoxious to the point that I did not accelerate more than 1/2 throttle and at a very slow rate to prevent the noise from occuring, which made driving very unsatisfying.
I tried header wrap because it was the cheapest solution + its a do-it-yourself job and it wasn't much of a help. The y-pipe noise is too high-pitched to be muffled by the header wrap. The only solution - with the exception of trashing the pipe- for me was to replace the flex joint.
I obtained a lined flex joint from Warpspeeed. Dallas was very helpful and also gave me a couple of pipe sections for the ends of the flex joint which was definitely needed (thanks!). My muffler guy replaced the flex joint and now the Y-pipe is quiet. There is a hint of exhaust rumble at idle- which i like-, but no annoying noises at any rpm, any rate of acceleration, any speed. Its like stock. The lined flex joint is the solution.
If your Budget y-pipe is making bees in the can/VW beetle type noises and you can't live with it then I recommend you to replace the flex joint. You can obtain one from Warpspeed. Make sure you let them know its for a Budget y-pipe, so he'll give you a couple of extra length pipe pieces because the unlined Budget flex joint is longer. Remember its 2.5in diameter.
My once $165 USD Budget price is now a $245 USD y-pipe. I wish I went straight to Warpspeed instead of dealing with this BS.
). The noise was sourced to the unlined flex joint (aka flex section) Budget uses. The noise was so obnoxious to the point that I did not accelerate more than 1/2 throttle and at a very slow rate to prevent the noise from occuring, which made driving very unsatisfying.
i really wanted the budget but now i am leaning towards a warpspeed because of this d*mn noise problem
has covering the flex section with header wrap worked for anyone?? i dont want the noise but the price of budget's y-pipe is so hard to ignore
oooo..... a quiet Y-pipe.. something i've been looking for! So it does depend on the brand of Y-pipe u get?? (noise-wise). Also, i have catback, so would that in combination make it louder? louder nois meaning the kind u can hear INSIDE the car w/ the window up (y-pipe resonating against interior cabin)
Originally posted by iregula
i have a budget and i dont have noise problems...if you want to save a lot of money for same performance go with budget
I have the new budget y-pipe bought on group deal and after 1000 miles on the pipe the beetle noise is much lower than it was when first installed. I no longer hear it at all after turning up levels on the bass tubes...
I had same BS VW noise!
http://forums.maxima.org/showthread....hreadid=133542
