Do you guys warm up your engine in the morning?
I normally warm it up about 2-3 minutes until the temperature raise a bit. And in the winter time, it takes about 5 minutes.
I read on a 99 ITR manual that it doesn't need to be warm up because they said that it will waste gasoline. and I couldn't find anything about it on Maxima manual.
What do you guys think?
You shouldn't let the car idle more than 1 minute, summertime or wintertime. It is better to drive off slowly than let the car idle for a long time because the engine will build higher oil pressure- which helps circulate the oil better- plus the engine will warm up much faster when you drive it. Don't rev the motor quickly (zing the motor) and rev too high for a first few minutes after driving off.
Read and enjoy:
http://forums.maxima.org/showthread....arming+morning
damn thanks for the link! Time to change an old habit
I searched before I put this new thread but I couldn't find it at 4th Gen forum..
It was a really good thread.
Originally posted by Nismo
about an minute then I just drive it, keeping the rpms low until the temp as at least off the cold mark
Re: Do you guys warm up your engine in the morning?
Originally posted by dedek
Do you guys warm up your engine in the morning?..
Re: Re: Do you guys warm up your engine in the morning?
Originally posted by pblaze
What you really want is for the oil temp to come up before you horse the engine.
Even though my max is garaged most of the time, I still run it for a few minutes before I need to go anywhere
i let my car warm up for about 5 min in the winter or untill the rpms reach under 100 then i drive slow untill the cars temp is normal in the middle, in the summer i do the same thing maybe about a min, is it necessaRY FOR U TO WARM THE CAR IN THE SUMMER
kjlouis
Nov 24, 2018 06:09 AM
conansriver
Sep 3, 2015 06:38 AM
