PLEASE HELP: Can't get indiglo guages over the needles
Old Aug 15, 2002 | 08:11 PM
MAXINXS's Avatar
I am putting on my reverse indiglo guages from United Indiglo right now. I got the guages on past the needle, but cannot get the center of the needle to go through the hole so the guage face will be flush. The hole is just too small. What did everyone else do???
Old Aug 15, 2002 | 09:15 PM
WizzaMax's Avatar
It should slip under the one side on the very bottom edge of the needle center and rest against the pin in the center of the overall needle assembly...then you slip it over gently on the top far corner from where you put it on...that is what I had to do for my Initial K.
Old Aug 15, 2002 | 11:36 PM
maxhead's Avatar
Wizzamax,
This is for Indiglo. I don't know if reverse indiglo works the same but.....
http://www.maximadriver.com/
Old Aug 16, 2002 | 08:08 AM
Ravq's Avatar
Originally posted by maxhead
Wizzamax,
This is the same procedure for the reverse indiglos.
Old Aug 16, 2002 | 04:19 PM
MAXINXS's Avatar
I ended up having to cut out the center of the guage to get it to fit over the needle. It did not work like I had planned. Doesn't look as good as I had hoped with the cuts. Thanks anyway to those that replied!
MAXINXS
Old Aug 16, 2002 | 06:35 PM
MIXXMAX's Avatar
MAXINXS
Oh, Oh!!!! I hope you didn't cut into the "filaments" where the light glows. If you did, more than likely, your screwed! It won't light up!!!
James92SE
142
Jan 2, 2024 09:23 AM
captchaos
Mar 15, 2016 12:18 PM
rnb754
Sep 14, 2015 11:39 PM
95Maxi
Aug 25, 2015 08:01 PM
