Easy way to remove rotors - correction
I gave you some bad info! The 2 40mm M10x1.25 bolts are used to remove the front rotors. You need 2 40mm M8x1.25 bolts to remove the rear rotors. You just screw the bolts into the rotor, alternately tightening the bolts until the rotor is loosened. Sorry!
Re: Easy way to remove rotors - correction
is it me, or this is a simple job. All the break job consists of is 4 blots and new pads. And maybe new rotors is they are that bad. Yes you should bleed the brakes everytime you do a break job but no one does that.
litch
123
Jan 4, 2024 07:01 PM
CAN-Toronto 97 SE BLACK w/ BLACK. PART OUT.
worldwiderecognized
Sep 24, 2015 06:56 PM
