The Bose answer you have been looking for.
Old Sep 13, 2002 | 12:16 AM
cobymoby's Avatar
I've started to rip apart my car now to finally use all of my old stero stuff. A lot of you have been wondering about how to connect the aftermarket amps to the Bose system without having an electrical engineering degree. I've done the reasearch and found that this is the best method:
PAC!!
Peek-a-boo-RCA's out of the Bose deck
Here's the harness, plugs right inline between the deck and factory harness with NO cutting, true plug and play. You get 4 channels AND a remote!!
Old Sep 13, 2002 | 12:18 AM
cobymoby's Avatar
Doing my best to run 4AWG along lines of the factory wiring:
The MB Quart tweets fit so perfectly in the factory location it was scarry!
Old Sep 13, 2002 | 12:24 AM
cobymoby's Avatar
Definately run power on the driver's side and signal on the passenger. Most of the factory wiring goes down the drivers side and you will also end up running a shorter power cable. Hopefully I won't have to install my PLD.
You can see how much less cabling there is on the passenger side.
I'll have Pictures of the amp rack this weekend
Old Sep 13, 2002 | 01:31 AM
mingo's Avatar
that's cool.. if i was to do my system over again, i mite think of going that route.. i like the "stock look"
Old Sep 13, 2002 | 09:10 AM
Maxima Dan's Avatar
I did a similar install using focals, but I didn't use the factory tweeter mounts. I didn't like the way they were angled down, pointing straight into the dash. After a bit of trimming I was able to fit the focal supplied mounts under the a pilar trim plate. This way they were angled up a bit and improved the sound stage a whole bunch.
Old Sep 13, 2002 | 10:36 AM
PoweredbyNissan
Re: The Bose answer you have been looking for.
PAC!!
So, how did you get the RCA cables to connect to the HU?
Old Sep 13, 2002 | 10:58 AM
cobymoby's Avatar
Re: Re: The Bose answer you have been looking for.
We sell an interface that goes in line between the HU and the factory harness. It plugs right in, no splicing or cutting. Email sales@berktuning.com
Old Sep 13, 2002 | 11:18 AM
phenryiv1's Avatar
Mod her. Ate her.
Re: Re: Re: The Bose answer you have been looking for.
How much $ are we talking here? When you said "remote" in the original post, you meant remote turn-on, right?
Old Sep 14, 2002 | 01:50 AM
cobymoby's Avatar
Re: Re: Re: Re: The Bose answer you have been looking for.
All three pieces are $65. Yes, when I said remote I meant remote turn on lead. No splicing of the facotry harness or using ghetto taps of the cigarette lighter.
Old Sep 15, 2002 | 09:40 AM
PoweredbyNissan
So, to install this interface you are selling, taking out the HU is required right? That seems like an impossible task itself.
Old Sep 15, 2002 | 05:28 PM
Triple8Sol's Avatar
I miss the .org!
Cobymoby, I am currently waiting for the exact same thing to arrive. You ordered the PAC AOEM-NIS2 right? I plan on adding my Basslink to my stock deck, so it should work perfectly. Good to see yet another person that has successfully gone this route.
Old Sep 15, 2002 | 08:09 PM
Audtatious's Avatar
Bandwagon Lover
The ROEM integrates a new HU with the factory system and the AOEM allows for external amp/processors to be used.
cobymoby, you are using the .75" Quart tweeters. Do you see a problem with using the 1" Quarts in the front pods without major modifications?
Old Sep 15, 2002 | 08:59 PM
cobymoby's Avatar
If you can't take out the stock HU then I don't reccomend that you go the DIY route. You should probably go to your local stereo shop and have them do everything for you.
Old Sep 16, 2002 | 10:11 AM
PoweredbyNissan
Re: Re: Re: Re: Re: The Bose answer you have been looking for.
Damn.... So, all of you guys know how to take out teh stock HU from a 2k2 maxima?! Are you kidding me?? Where did you guys learn to do this stuff?? what age group are you guys in by the way?
Old Sep 16, 2002 | 10:22 AM
phenryiv1's Avatar
Mod her. Ate her.
Re: Re: Re: Re: Re: Re: The Bose answer you have been looking for.
I am 25. I have never taken out a 2K2 HU. BUT given the fact that in almost 100 "friendly" installs over the last 9 years I have never failed to get a HU out (w/o breaking things) I am sure that I can figure it out.
It is not by any means an impossible task. I think what cobymoby may have meant to say was that if you think that the prospect of removing the stock HU is that daunting, you might want to have it done professionally. I would argee to some extent, but would also point out that DIY is the best way to learn your way around the car. If nothing else, pay for the crutchfield direction set (www.crutchfield.com for info) and learn how to do it. It is a LOT easier than is seems at first. It took me a while to get my 96 apart (compared to most domestic dashes), but in the end it was worth it. The kicker? I did not even mod the stereo, just took it apart so that I knew how to do it if the time comes.
Everyone who has installed, whether it is a one-time thing, a hobby, or a profession, started with a first car. It might as well be your own.
Old Sep 16, 2002 | 02:59 PM
Triple8Sol's Avatar
I miss the .org!
I'm 21...you just learn alot from the .org, and from friendly helpful members.
The ROEM-NIS2 is what I have right now. They sent me the wrong kit. So I'm waiting for the AOEM-NIS2 to arrive. I decided to keep my stock HU, and just add the amp/sub. www.go2pac.com
Old Oct 2, 2002 | 08:10 AM
rebos456's Avatar
any update on your install? How does the system sound? Let us know...
Old Oct 4, 2002 | 08:04 PM
roruiz's Avatar
Where did you buy the adapter and how much?
thanks
Old Oct 6, 2002 | 06:02 PM
Triple8Sol's Avatar
I miss the .org!
For PAC's website, go to www.go2pac.com. I think you can call them and order it directly. It will probably be cheaper if you check their list of authorized dealers and find one in your area. I got the kit for $65 + tax.
Old Oct 7, 2002 | 12:43 PM
TimW's Avatar
The silent but deadly Moderator
CM, you never said which model Quart tweets those were, I kinda wanna do the same thing.
doctorpullit
Mar 29, 2016 11:08 AM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
lrb6805
Sep 24, 2015 05:03 PM
