How do I know if I have an exhaust leak?
I recently installed a magnaflow muffler, the place where the mid pipe connects to the extension that goes to the muffler seems be sort of loose....... when I noticed it, right away I thought that maybe I also have an exhaust leak because of the looseness.....
so how can I find out if its leaking or not??
thanx in advance
thanx in advance
Depends
Did you install your muffler yourself or did a shop do it? Personally I would take it in to a Midas or Minekee shope to have them test to see if there is indeed a leak. It should only cost about $20-30 so that shouldn't be too much of an issue. Sorry if this doesn't help but that's all I got...Word.
-King Ryan-
-King Ryan-
While the engine is idling, have someone cover the exhaust tip w/ their shoe while you listen to the questionable joint. If it is leaking you should hear air escaping from the joint. Also, if it's leaking, you should also be able to feel air escaping through the seam as well. Good luck.
Originally posted by carnal_c30
you can also hear a buzzing sound often as the gaskets vibrate it happens when you're on the gas you can hear it if you drive next to a median or some other solid structure
I had a shop do the install for me...... and as someone mentioned when I put my hand around the connection there seems to be no air escaping and no werid sound so I guess its not leaking
thanx for the help guys....
depends on how bad of a leak you have... my car wasnt any louder but i had an exhaust leak i could hear it... crushed crush seal on the y-pipe boltimg up to the manifold... small leak but it was audiblle i hated that damn buzzing sound
litch
123
Jan 4, 2024 07:01 PM
oh well. I like it!
