quick question to anyone with alarm
If you have an aftermarket alarm, Lets say a clifford g4, does the security LED in the dash still blink? what happends to the stock alarm? does it set off with the aftermarket alarm or is it eliminated?
Re: quick question to anyone with alarm
I have the Viper 550ESP. The stock alarm is still active too and the OEM Security light still blinks. In fact, once I had the stock alarm go off but not the aftermarket alarm. It turns out I hit the trunk button on my keyfob. I guess that doesn't trigger my aftermarket alarm. Other than that, I've only had the aftermarket alarm go off without the stock alarm.
Later,
-Nick
Later,
-Nick
some of the nicer alarms can enable/disable the stock alarm. You should have any problems. If you really need to, hook a wire from the alarm to the stock disable wire for ground...so when you disarm your new alarm, it'll ground the stock alarm and disable the stock alarm as needed.
Jae
Jae
Mar 12, 2020 12:06 AM
pears
Sep 18, 2015 05:25 AM
