Both Fog lights went out...
I noticed both of my fogs quit working. Both at the same time. About a month ago i put hyperwhite bulbs in. All my headlights and things are fine. Would that be the problem? Is there a fuse for the foglights anywhere?
I think there is a fuse - I'm not sure what it's labeled. Just check em all if it isn't clearly labeled. There is also a relay in the engine compartment you might want to check as a last resort. Also, not to insult your intelligence but you're sure the switch on the stalk is set to on right?
Good luck.
Good luck.
Ok i seen a fuse labeled FR FOG in the box next to the battery, its not blown so thats not the problem. Guess ill look at that relay. It could be burnt bulbs but i just dont think both would go out at the same time, but i guess its possible.
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
