Double sided adhesive..
Old Sep 19, 2002 | 03:36 PM
jjs's Avatar
jjs
has anyone had success removing any part of the body (not just emblems) that uses this stuff (whether or not other clips or fasteners are involved)? What was the technique?
This is specifically directed at DIY'ers, not taking the car to a shop.
Thanks!
Old Sep 19, 2002 | 05:38 PM
ms.thicknes's Avatar
Re: Double sided adhesive..
Thanks!
what adhesive I could not get off with my fingers.....I clay-barred off
Old Sep 19, 2002 | 06:52 PM
BigDogJonx's Avatar
Re: Re: Double sided adhesive..
He meant getting the actual parts off, not just the glue...... Such as the side door gaurd. It is secured with clips and double stick tape.
It is fairly hard to do the side door gaurd since you dont want to use a screwdriver to dent the door itself. It was meant more for when the car got into an accident and it was probably half off and they can replace it from there easily.
Dixit
Old Sep 19, 2002 | 07:20 PM
Richard Scott's Avatar
We use tape at the place I work that has adhesive on both sides and the prefered method of release is alcohol. You might try that.
Old Sep 19, 2002 | 07:53 PM
soopermax02's Avatar
A heat gun usually works very well for adhesives. It wouldn't hurt to try, just don't turn it up too high or leave it on one spot too long. I imagine it could get hot enough to cause damage if used improperly.
Good luck, hope it helps some.
Old Sep 20, 2002 | 07:01 AM
jjs's Avatar
jjs
Thanks gang!
Yes, it is in reference to removing some of my AE body kit (don't ask ).
Old Sep 20, 2002 | 07:26 AM
Vadim's Avatar
Thanks!
WD-40, then use a fishing line to get around it
Old Sep 20, 2002 | 07:35 AM
jjs's Avatar
jjs
Thought about the line, but way too many weird and tight contours (front lip).
Old Sep 20, 2002 | 08:13 AM
MaximaMan77's Avatar
GOOGONE has helped me in the past.
Old Sep 20, 2002 | 08:15 AM
jjs's Avatar
jjs
Alone or in conjunction with heat/line/etc.?
Old Sep 21, 2002 | 12:42 PM
I used it with fishing line but in your case you might want to use the line where you can and lots of goo gone to keep it from readhearing. Then soak the areas you can't use line on and start prying it off. Alcohol may help but be sure to use the goo gone once it has seperated because the alcohol will make the adhesive real sticky. Also try calling a body shop and see if they have any pointers.
Hope this helps.
user 11122324
42
Jul 18, 2022 03:35 PM
Andy29
Sep 29, 2015 05:32 AM
Socalstillen
Sep 26, 2015 12:01 PM
Noela
Sep 26, 2015 08:22 AM
BrandonCause
Sep 14, 2015 10:41 PM
