Losing 2 to 3 PSI a day
Old Sep 22, 2002 | 05:36 AM
woreyah's Avatar
Hey folks,
I noticed I'm losing about 2 to 3 PSI a day on my rear passenger side tire. The car is only 4 months old. Can this be repaired? I honestly don't know, I've never had tire issues. I had Michelins on my SHO and didn't have problems for the 3 1/2 years I had the car.
Old Sep 22, 2002 | 05:40 AM
mpc578's Avatar
Whether or not it can be repaired depends on where the leak is and what type of hole there is in the tire. If it is like a nail, etc in the tread, it can be repaired, but if it is in the sidewall you are S.O.L.. If there is no visable leak, it could be coming from the stem, or worse yet, if you hit a pothole, etc, you could have bent your rim. My advice would be to take it to a trusted mechanic/tire shop, have them throw it on the lift, and they can check it for you really quickly (or jack up the car and do it yourself). I am pretty sure our tires come with some type of warranty(like 1 yr) if it is a manufacturing defect, but more than likely you are gonna be paying for whatever remedy is needed.
Old Sep 22, 2002 | 12:10 PM
woreyah's Avatar
Thanks for the info. I'll take it in tomorrow.
Old Sep 22, 2002 | 04:39 PM
max'n out's Avatar
The stem has a little thing in it that needs to be tight check that, it's real easy to tell when you pull the cap off, just listen for a sizzle air sound.
Old Sep 22, 2002 | 05:19 PM
woreyah's Avatar
How do you tighten it? Turning it with a needle nose plyers?
Old Sep 22, 2002 | 05:30 PM
PoLo's Avatar
2-Wheelin it...
bro, it's prolly just a nail. i had my car 3 months, got a nail in there...lost about 5psi a day. who cares if you only had it 3 months. nails don't feel sorry for you. they'll f*ck you over whenever they want.
$5 to patch it up and life goes on.
Old Sep 22, 2002 | 05:46 PM
woreyah's Avatar
I'll find out tomorrow
Old Sep 22, 2002 | 08:23 PM
bert's Avatar
Get them to put a new valve in. While the tire is off, you (they) can inspect the rim / tire for damage. If you spot damage then you can fix it, as appropriate.
If the leaking stops, you know what the problem is, it the leaking doesn't stop you know what the problem is not.
Old Sep 22, 2002 | 09:19 PM
CO2kmax
That is sort off a slow leak but if u have a big tub that u can fill up with water. Take off your wheel and put it in the water. Bubbles will come out of the area that has the leak.
Old Sep 22, 2002 | 10:26 PM
max'n out's Avatar
No, you need somthign much much smaller...There is a tool for it...But if you don't have it sometimes small twizers can work.
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
gigabyte
Jan 6, 2017 06:05 PM
D Mason
Jun 21, 2016 04:43 AM
