Losing 2 to 3 PSI a day
Hey folks,
I noticed I'm losing about 2 to 3 PSI a day on my rear passenger side tire. The car is only 4 months old. Can this be repaired? I honestly don't know, I've never had tire issues. I had Michelins on my SHO and didn't have problems for the 3 1/2 years I had the car.
Whether or not it can be repaired depends on where the leak is and what type of hole there is in the tire. If it is like a nail, etc in the tread, it can be repaired, but if it is in the sidewall you are S.O.L.. If there is no visable leak, it could be coming from the stem, or worse yet, if you hit a pothole, etc, you could have bent your rim. My advice would be to take it to a trusted mechanic/tire shop, have them throw it on the lift, and they can check it for you really quickly (or jack up the car and do it yourself). I am pretty sure our tires come with some type of warranty(like 1 yr) if it is a manufacturing defect, but more than likely you are gonna be paying for whatever remedy is needed.
Originally posted by max'n out
The stem has a little thing in it that needs to be tight check that, it's real easy to tell when you pull the cap off, just listen for a sizzle air sound.
Originally posted by woreyah
How do you tighten it? Turning it with a needle nose plyers?
$5 to patch it up and life goes on.
Originally posted by PoLo
bro, it's prolly just a nail. i had my car 3 months, got a nail in there...lost about 5psi a day. who cares if you only had it 3 months. nails don't feel sorry for you. they'll f*ck you over whenever they want.
Get them to put a new valve in. While the tire is off, you (they) can inspect the rim / tire for damage. If you spot damage then you can fix it, as appropriate.
If the leaking stops, you know what the problem is, it the leaking doesn't stop you know what the problem is not.
tarun900
19
12-20-2021 06:57 PM
