Benefits of porting MAF?
Old Sep 25, 2002 | 06:04 AM
mzmtg's Avatar
Minister of Silly Walks
I'm both bored and broke, so I'm always looking for cheap ways to mod. Would porting my MAF make a noticeable difference? I just want to cut down the "bottom half" of the huge post in the middle of the sensor. This would remove a thumb-sized impediment to airflow. Seeing as my engine as all stock, I'm guessing this is not worth the time/risk involved.
I figured as long as I'm in need of a $100 knock sensor, I might as well mess with a $500 part that the car cannot run without...
Old Sep 25, 2002 | 06:30 AM
njmaxseltd's Avatar
If you change the MAF's port size in any way it will throw off it's calibration. More air will get past it without being measured which could cause a lean condition. Then your o2's will detect it, adjust the ECU. Hummmm on second guess, maybe it will work..
Then agian, it could cause a hesitation.
I think you should try it and give us some feedback.
Old Sep 25, 2002 | 06:37 AM
mzmtg's Avatar
Ok, I'll go for and report butt-dyno results...
But, in case it all goes to hell, I'm starting the "buy Ben a new MAF fund."
My PayPal ID is bennett.garner@normentind.com
All contributions are appreciated
Old Sep 25, 2002 | 06:42 AM
njmaxseltd's Avatar
Old Sep 25, 2002 | 07:21 AM
96sleeper's Avatar
Re: Benefits of porting MAF?
if you figure up the area, the TB is still the smallest part in the intake tract. Even when you take into consideration the screen as a 15% blockage and take the area of the top and bottom post, it still flows more than the stock TB. I had the same plans but when we took it off and started measuring, I realized that there was use without a larger TB.
Old Sep 25, 2002 | 07:57 AM
MardiGrasMax's Avatar
I did this a few k miles ago, no noticable loss of drivability. As far as a power gain, theoretically yes, but I have no proof. I took a hack saw blade and one sided blade holder and sawed off the lower post. Then I used a dremel to clean it up. FWIW I have been doing allot of highway driving recently and am still getting 26-28mpg.
Old Sep 25, 2002 | 11:20 AM
NmexMAX's Avatar
dot dot dot ...
I thought you already changed your knock sensor just recently? Didn't you run a 16.xx before the k.s, and the 15.2 just after you replced it?
Back to the subject, is your screen removed from your MAF? I always wanted to try out this mod, or something similar to see the gains, because after my MEVI, I'm quite broke.
Old Sep 25, 2002 | 12:00 PM
mzmtg's Avatar
No, I ran a 16.xx my first time at the track and ran a 15.2 after I learned to drive and the weather got colder.
Old Sep 25, 2002 | 12:20 PM
96sleeper's Avatar
I read everything I could read on the internet about removing it, and I decided to remove it. I sanded the end where the screen was and got rid of all of the rough edges and made it into a kind of venturi shape. I have noticed no ill effects, but I also didnt notice any gains from it. We figured it to be about a 15% restriction in airflow, but like I said earlier the throttle body is still the most restrictive part in the intake. Someone needs to come out with a 65mm throttle body for us N/A guys. I dont really see spending $200 to get mine ported to 63.5mm and still not have it the size I want. I mean come on, they make 68mm throttle bodies for civics.
Old Sep 25, 2002 | 12:50 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
yeah i've got a spare maf if urs dies =)
Old Sep 25, 2002 | 02:06 PM
DaddyMac's Avatar
go ahead and port it, then I can sell my MAF
Old Sep 25, 2002 | 03:43 PM
Nismo87SE's Avatar
Porting the MAF is only good if your topping it out. The se-r guys sometimes port the stock maf to raise the limit from 260whp to 300whp. After that most go with a cobra MAF or Z32 MAF. From what I seen the stock maf should be fine for 300-350whp.
Old Sep 25, 2002 | 04:55 PM
mzmtg's Avatar
Re: Re: Benefits of porting MAF?
Um, what have you "seen" about the horsepower limits of the MAF on a 95 Maxima?
Old Sep 25, 2002 | 05:35 PM
Bags's Avatar
VG Ridah's Biatch Hoe
I am assuming you have seen mardigras posts on the pathfinder TB?
I also agree with you 100% a ford focus can get a 70 mm TB.... and a V8.
Again reasons to mass email companies..lol
Old Sep 25, 2002 | 09:01 PM
henock
is this what you mean: http://www.greghome.com/Greg's%20Garage/1999%20Nissan%20Maxima%20SE/MAFSensorMod.htm
if so, read the article, if not, ignore me
Old Jul 14, 2003 | 10:44 PM
BEJAY1's Avatar
Conecarver
65mm?
Sorry to exhume this from the dead but I just read about a 65mm TB on B13 models.
http://www.nissanforums.com/showthre...threadid=10516
I read the 70mm Pathfinder was a bit too large so maybe one of these will bolt up too?
Old Jul 14, 2003 | 11:47 PM
Broaner's Avatar
2060lbs and falling...
Alright, lots of things.
1. I removed my screen, from my pipe that is, because it had rediculous amounts of resin on it. No, I removed my MAF screen because I did a homemade intake. All is good so far. Done almost a thousand with not problems. Couldn't tell gains because I did it at the same time as the cone.
2. Why even consider 63-68 mm TB mods when u can get a 70mm TB from a salvage Pathfinder for nothin'.
3. I would be interested to get the real stats on chopping the MAF with a diff TB.
Old Jul 15, 2003 | 12:11 AM
RA030726's Avatar
I'm nutty for Nissans
I cut the MAF intake adapter plate off all together. I was too cheap to buy a MAF adapter and too stupid to think of the HAI thing. Anyway removing the screen did nothing 4 me and its been about 40,000 miles since i did it with no problems (I think).
Old Jul 15, 2003 | 06:05 AM
BEJAY1's Avatar
Conecarver
[QUOTE]Originally posted by broaner22
[B]Alright, lots of things.
a) MardiGrasMax mentioned he could only open up the intake port to like 67mm
http://forums.maxima.org/showthread....hreadid=141403
b) The Pathfinder TB required a bit of work to install ie plate, spacer, etc. - not a direct fit
c) I'm not running 300+hp and don't need that large. Other boards mentioned losing air velocity and response through the system going too large over stock.
Old Jul 15, 2003 | 06:33 AM
krismax's Avatar
Father of the 00 VI
[QUOTE]Originally posted by BEJAY1
[B]
One thing you mhave to relize is the stock throttlebody for are cars isnt any bigger really than a sentra or b-16 engined car, trust me when i put it on it was a noticed power gain and ran lean, for a fact.I think thats why my headgasket went and probably still are running lean, all 4 of my fuel trims are at +21%. At idle my scan tool was even showing increased air flow.
I opened mine more than 67mm i put mine more into the bend.
Old Jul 15, 2003 | 07:40 AM
96sleeper's Avatar
Re: 65mm?
I never could find a TB from a S13, I looked and they are too rare. I ended up doing the pathfinder TB and it feels good so far, haven't verified gains at the track though. I opened up my intake manifold more than 67mm as well.
TallTom
57
Oct 14, 2025 05:16 PM
JonBlz
Oct 5, 2015 06:02 PM
