Engine tap noise
Engine tap noise
I have this strange noise that I can only hear at idle in park or when I'm driving real slow. Now the engine drives real smooth and I don't feel any problems. It's a very quiet noise seems to come from the front driver side. It goes tap tap tap, then goes away. Was wondering if anybody else had this sound and knows what it is. I drive a 98. Most people wouldn't hear it, unless they are listening for it.
Re: Engine tap noise
Actually, I think i noticed this sound too last night after installing my frankencar midpipe... i was sittin there listning for sounds and i heard a steady sounds of *clicks* and it came somewhere from the passenger side tho.... most likely the timing chain, i hope.
The timing chain usually rattles upon start up and then becomes quiet. It doesn't tap, it rattles, which by the way is your first indication that your chain tensioner is failing.
What you may be hearing is valve trane noise and it's perfectly normal on our VQ engines. Our valve setup is a bucket and shim design, which is a bit noisier then a hydraulic lifter design.
Originally posted by njmaxseltd
[B]The timing chain usually rattles upon start up and then becomes quiet. It doesn't tap, it rattles, which by the way is your first indication that your chain tensioner is failing.
ballerchris510
Sep 11, 2015 05:29 PM
