Problem areas on 4th gen Max?
I'm considering buying a 1996 Maxima with an automatic and 108,000 miles. Are there any particular problems I should look for? Under normal driving conditions, how long should the automatic transmission work without a rebuild?
I plan to take the car to a mechanic for an inspection before purchasing but I thought I would consult the Maxima experts first.
Re: Problem areas on 4th gen Max?
Tifosi
1. Starter : Go in the early morning when it's still cool and start the car. See if it makes any sort of grinding noise.
2. Mileage is getting up there. You'll probably need new struts soon. The dust boots are probably gone or very brittle.
3. Check the exhaust system and look for any serious rust. Heat shield supports tend to rust through.
4. See if you can get any past repair records. There was a recall on one of the O2 sensors a few years ago for the 95 models. Probably applied to 96 too.
can't think of anything else at the moment..
Good luck.
i just bought a 96 SE Auto to replace my 95 SE 5spd (actually won it on ebay). the new one is an auto with 98K and shifts just like my friends '00 SE with 22K, very solid, very smooth. You might notice when doing a rolling stop and stepping on the gas again it will feel like its slipping...this is normal i guess.
The 95 and early 96's had a timing chain tensioner rattle when started cold, or after sitting for a few hours. It sounds really bad atually, then quiets down as soon as the engine has been running a few seconds and built oil pressure. Not a fun or cheap fix ($200 in parts plus a weekend if you are a seasoned mechanic, or $1100 at the dealer). The rattle will even be there just reving the engine a little....at least until the engine is warmed up.....my car did it almost constantly by the time i fixed it...especially in the cold months too.
I had reservations about buying a high mileage automatic, but others on the forum that have done good maintenance have reported 150K or more. color of fluid means nothing...if it smells burnt, that's bad.
If you are in a northern climate there can be some noticable exhaust system corrosion.
And the earlier comment about strut boots being bad...oh yeah. My boots are cracked but the struts are firm yet, and the tie rods and ball joints are nice and tight yet. On my 95 the swivel plates for the front struts were dry as well as cracked boots (bought it with 70K sold at 84K).
you can expect a few sensor failures unless they have been replaced already...egr temp sensor, any of the three O2 sensors, knock sensor.
I see no reason this car won't go 130K+ before i have to really put anything major into it.
its all about prior maintenance....you can drive the pants off a car but if he took care of it, it will be fine. just don't pay too much.
good luck....john
good luck....john
Not major prob
After 6K of driving my 95, I find no major prob. Bought at 78K, now 85.5K
Just make sure you do a throttle body cleaning and the car should be starting fine.
Transmission is like new. Don't butcher your tranny by doing the so called "manual shifting."
And be aggressive only when required
Re: Re: Problem areas on 4th gen Max?
Originally posted by Tifosi
I have found some but don't remember what they were now. You can do an internet search on Nissan Maxima service bulletin or technical bulletin. Should give you some ideas what are some common problems. And if you car does have those problems, take it to a dealer and a printout of the problem from the bulletin, since it's a known issue, they most likely will fix it for free.
Tifosi
Tifosi
Originally posted by laba
Anyone know how much a throttle body cleaning goes for? I just hit 50K on my 97, I'm wondering if/when I should get it done.
I went and bought a can of cleaner for less than $5.00.
Motorvate has instructions posted.
They suggest removing the whole air intake.
I just removed the rubber accordian bit
in front of the throttle body...
yeah, you'd have more/easier access if you took everything off.
I was just lazy. I was able to get it pretty clean though
and performnance did improve.
If you are buying the Maxima from a dealer here's a tip. Once you have finished negotiating the price you can show them you are still not completely satisfied and tell them you'll buy it if they extend the used car warranty (get it in writing). I got six months instead of three. Also you can try and get a carfax report on the car (you'll need the VIN).
I have 59,400 miles on my Maxima and the starter already failed so I think that's something you should really check.
Common 4th gen maxima problems:
knock sensor
rear e-brake cables
starter on 95-96
Common things to check to all used vehicles:
suspension (boots, bushings, struts/shocks)
carbonization of pistons (rattle-tap going up hills)
timing belts (not on maximas, but on most other cars ATM)
accessory/power steering belts (check for wear)
fluid flushes (tranny/gear, brake, radiator) and filters (air, fuel)
brake wear (rotors, pads)
service records (regular maintenance?)
I'm probably leaving stuff out but it's been a long day
knock sensor
rear e-brake cables
starter on 95-96
check out this website www.motorvate.ca
i think the most importain is oil leak,make sure you don't see oil leak in the back of timing chain case($2,400.00/21hrs),rear main seal($1,230.00/11hrs)that's the quote i got from my dealer.the mechanic told me there is a o-ring behind the timing chain case that will leak in time,mine did.
so i am going have to find sometime to fix it myself,prolly with the help of my friend.
Ok well seeminly none else has the usual problems...watch out for the knock sensor, the O2 sensor, the temp sensor, and the cv boots/joints. I know alot of people including myself with these problems, my boots went not 3 months after I bought my car.
Finkle
Sep 27, 2015 09:53 PM
Greenmaxspeed
Aug 31, 2015 09:06 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
