differential bearing? hum hum hum noise?
Old Oct 9, 2002 | 03:01 PM
NISMOPower's Avatar
i keep hearing a hum hum hum noise from the right side. i noticed that it was more near the transmission...I do have a very small tranny leak. the thing is that when my steering wheel is straight i can hear the noise and if i turn any more right from the center it will make that noise. Faster I go louder it gets. when i take a left turn the sound goes away completely. I can kind of feel the noise in the gas pedal too. what should I do?
Chris
Old Oct 9, 2002 | 03:43 PM
NISMOPower's Avatar
anyone help?
Chris
Old Oct 9, 2002 | 05:24 PM
maxperformance's Avatar
Chris
I was racing about a week ago and i hit a curb, long story but thats not the point. I had to get a new control arm and a new spindal. But i also had to get a new bearing in the front right of my max, it was a little over a hundred. So the reason for this post is that the part isnt too cheap man. good luck
Old Oct 9, 2002 | 07:46 PM
iwannabmw's Avatar
Re: differential bearing? hum hum hum noise?
Chris
Sounds more like a wheel bearing to me.
You can double check the differential bearings fairly easily though. Just grab the shaft and see if it has any play in it. If it moves up or down, that's your problem. If not, I'd look at the wheel bearings.
Old Oct 9, 2002 | 10:02 PM
NISMOPower's Avatar
Re: Chris
Hey this started happening after I had hit a curb on my front right tire too...does that mean the accident caused it...I mean like is there a way to prove that it was from the accident and have the insurance pay for it???
Chris
Old Oct 9, 2002 | 10:24 PM
NISMOPower's Avatar
Should I attempt the wheel bearing myself to save money??? Is it pretty simple to do??? Only stuff I've done is brakes, remove plenum and throttle body to get to valve cover, fuel filters, fuel lines, wheel bearings on one other american van, exhaust, suspension work. Anyone think I may be able to do this with ease???
Chris
Old Oct 10, 2002 | 05:56 AM
Stephen Max's Avatar
Chris
Replacing the wheel bearing is not an easy job unless you have the right tools. You can go to motorvate.ca and find a how-to on wheel bearing replacement and how to make your own bearing press tooling. I did that and still had a lot of trouble. Fortunately I have a friend who is a mechanic and I borrowed his $750 professional wheel bearing removal and installation tool (called a Hub Buddy, I think, or maybe Bearing Buddy, I can't remember). Then it was easy. Anyway, bottom line is it's not for the faint-hearted.
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
Andy29
Sep 29, 2015 05:32 AM
Pied
Sep 26, 2015 03:29 PM
