Sidemarker Light Bulbs - HELP!
Re: Sidemarker Light Bulbs - HELP!
Originally posted by busterdawg22
Help! How do I change the bulb in the sidemarker (not bumper) lights on my 1995? I just bought two Polarg M9 bulbs, and I want to use them! Please help!
Re: Re: Sidemarker Light Bulbs - HELP!
Originally posted by ReichMax97
This info should be in your owners manual under the how to do yourself section. But heres what you do: Take a screw driver or anything that is skinny and pry the marker off from the front part of it (it will pop right off). It will dangle down, just take the wire thing out of the lens, take the bulb out, put the new one in, stick the bulb back into the sidemarker lens, and pop back in to place. Hope this helps.
-Cyrus
Re: Re: Re: Sidemarker Light Bulbs - HELP!
Originally posted by Vyrus
Don't forget the screw up top that connects to the headlight assembly!!!
-Cyrus
-Cyrus
oh ya THOSE things....heh, i thought u were talking about the sidemarks...those are the clearance...those things are a b!tch. there was some type of hangar holding mine in place....little metal thing holding it back, try to look in there, and see if you can unhook it...that thing ****ed me off.
Re: Re: Re: Re: Sidemarker Light Bulbs - HELP!
I tried unscrewing the screw that connects the headlight assembly to the sidemarker, then I tried prying the sidemarker light off with a screwdriver. It seems like there is another screw holding the sidemarker in somewhere because I can get it loose, but it won't come out. Is there something I am missing?
It just has to be carefully pried out. My right side took forever and the left came right out because I understood how it was in there.
Pry it carefully and wrap the end of your screwdriver in a thin towel or old t shirt do you do not crack or scratch anything.
D
my right side popped right out my left was a biatch.
yeah everyone always makes it sound so easy. i chipped a corner on my left one ****ed me off. and to think i dont even like the way that bulb looks with the others. but its damn bright
Clearance Lights
It definitely didn't say how to do it right in my manual. The info at maximadriver.com is good. Basically, there is a ball joint behind the light that you need to spray some wd-40 on and then pry open with a flat head screw driver. I did a writeup on a clearance light mod some months back. It doesn't tell you how to get it off, but it has some pics of what the back of the lights look like...
http://hakker.org/maxima/cl-switch.html
If that helps...
If that helps...
The Frye
Sep 2, 2021 11:03 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
