keyless remote
Old Dec 26, 2000 | 12:54 AM
Ch12i5
hi, doesanyone know where i can get a keyless remote? i'm not really into getting things from ebay...but yeah, i'd like a good price on one. thanks
Old Dec 26, 2000 | 04:14 AM
jlwardn's Avatar
keyless
I sell them on Ebay. Right now I have a couple for the 2000 models. I will see If I can get one for our model for you.
Did your car have one from the factory?
Old Dec 26, 2000 | 08:19 AM
Ch12i5
nope i didn't get any keyless remote from the factory...i bought my car (96 GXE) used, and since everyone is talkin about how you can simply buy a keyless remote and program it, then i'd like to do that. the only thing is, inside the engine bay on the left side there is a fuse box. one of the is labed keyless entry or something, and there's no fuse there...does that mean keyless won't work?
Old Dec 26, 2000 | 10:03 AM
Daniel B. Martin's Avatar
Originally posted by Ch12i5
... inside the engine bay on the left side there is a fuse box. one of the is labed keyless entry or something, and there's no fuse there...does that mean keyless won't work?
That's a good indication that your GXE is not equipped with the keyless entry feature. Here's another check you may make to confirm this hypothesis.
The factory service manual refers to the keyless remote feature as the Multi-Remove Control System. It uses a Multi-Remote Control Relay. Look to see if your car has this relay.
1) Open the trunk. Remove the trunk compartment floor carpet and the fiberboard spare tire cover. These are removed with your hands; no tools are required.
2) Remove the trunk trim which surrounds the latch mechanism. The plastic fasteners which secure it are quarter-turn latches and come loose easily when turned with a Phillips head screwdriver.
3) Look at the area of the trunk latch mechanism, made visible by removal of the the trim panel. Locate electrical connector T5. This is a brown plastic connector with 6 terminal positions. If your Maxima does not have the keyless entry feature you will find connector T5 taped up so it does not rattle, but with no relay plugged into it.
4) Re-install all the trim you removed.
This whole operation should take three minutes.
Old Dec 26, 2000 | 08:25 PM
maxspeed5's Avatar
I know my GXE dosen't have keyless, but would like to add it. Is it easy to do (like add a fuse and that thing in the trunk)? Cost? Thanks...
ToTheMax305
Sep 23, 2015 09:11 PM
flu2000
Sep 14, 2015 12:34 PM
intimidator
Sep 5, 2015 07:23 PM
Hailstatejig
Sep 2, 2015 06:52 AM
