Dunlop or Yokohama?
Go to http://www.tirerack.com
You'll find all the info you need. I have Dunlop sp5000s and love them, very good traction for all-season tires.
Originally posted by roggie93ser96se
do yourself a favor and get the Bridgestone Potenza RE730's, best tire for the Max out there...
Same
I say the thread and was thinking Potenzas before i even read the whole thing, get them.
________
Pattaya Heights Condos
________
What are your needs/driving conditions?
Summer or All-season?
Dunlop SP SPort 5000 and Yokohama AVS dB Decibel are probably the 2 best all-season tires out there. I like the Dunlops personally. I think pricewise tehy win out as well.
If summer only, I'd get the Bridgestone Potenza RE730 as has been stated several times in the Thread. I've heard great things about teh Firestone Firehawk SZ50 and the SZ50 EP seems to be an improvement on that. I think that they cost more than the Bridgestones though
Originally posted by MaximaRacer
I need to get new tires. Which ones are better for traction and tread life?
I have used all tires being mentioned.
Dunlop SP8000 on the max and on our last car a subaru SVX
good bang for the buck with good overall tire wear and performance in wet and dry conditions
Yokohama avs were also on the max. We felt that it wore rather quickly though performed well, however a little more expensive then the Dunlop sp8000
I have the Dunlop w-10 on the volvo 850 turbo. nice cheap tire. though they are not z rated, however I dont think we will be running our maxes at that high speed for prolonged intervals.
Finally, I had falkens on the volvo. great dry performance. Thought they sucked in the rain though even though they had that rain groove.
I had Bridgestone potenzas on my 88 mustang 5.0. Loved the tire and pretty cheap. Performed extremely well when we used to race the car.
Just to give you some options and opinions. If I had to rate them:
1. Dunlop SP8000 or the Bridgestone
2. Yokohama AVS
3. Dunlop w-10
4. Falkens(unless you are in dry weather quite a bit. then they worked well)
Hope I helped
2. Yokohama AVS
3. Dunlop w-10
Hope I helped
The Dunlops give great lateral traction as well as forward traction. But I think the wet traction could be a little better. It can be tough in a 5-speed without spinning the tires when it's wet. If you get the Dunlops be sure to rotate them at 3k-5K as they will wear early if you don't.
TMAX
TMAX
Originally posted by Maximum Performance
yokohama avid u can get it at tire rack for around $50 each, depends on the size u want. these are very quiet, comfortable, provide good traction and handling, best bang for the buck
ARE THESE ALL SEASON TIRES? THANKS. PPL ARE SAYING GOOD THINGS ABOUT THEM....AND I WANT A TIRE THATS ALL SEASON
Yes
What about TOYO????
They are the best tires in my opinion that's because I live in miami and it doesn't rain that much here so I'm str8. I think you should go with the yokohama's. I think they are softer than the dunlops, but not to soft.
Team STILLEN
Aug 10, 2015 04:29 PM
humaras
Sep 6, 2000 06:35 AM
