RPM question
Old Nov 2, 2002 | 09:28 PM
taggate's Avatar
RPM question
Hi people,
I change my spark plugs and the pcv value yesterday and when i turn on my car the RPM needle goes above one. Once the car is warm up the needle goes below one. Is this normal ? Any input is welcome. Thank you in advance.
Old Nov 2, 2002 | 09:33 PM
98SEBlackMax's Avatar
Maxima.org Insomniac
Re: RPM question
Originally posted by taggate
Hi people,
Yes the stock Maxima engine idles higher 1 K ~ 1.5K rpms when its a cold start and then normally drops below 1K and stays around 750~850 rpms when it warms up.
Old Nov 2, 2002 | 09:37 PM
taggate's Avatar
oo. thanks
Old Nov 2, 2002 | 11:14 PM
NiNe7-Gxe's Avatar
Re: Re: RPM question
cold start my car is 1-1.3k and when its warmed up its 500-600 is this normal? 500-600 seems very different from your 750-850
Old Nov 2, 2002 | 11:16 PM
iansw's Avatar
Re: Re: Re: RPM question
Not too abnormal. Some cars are slightly different.
I'm SC'ed, and I idle at about 650. I idled at 600 when I was stock.
IanS
Old Nov 3, 2002 | 06:52 AM
dwapenyi's Avatar
If you clean your throttle body you'll notice an even bigger jump, depending on how dirty your TB was before. I cleaned mine after 100K miles. Before cold starts would happen at 1100 rpm. After the cleaning, 1500 rpm. Also, low end pickup was better, too.
DW
Old Nov 3, 2002 | 09:26 AM
DW
Hmmm I went to clean my TB at 61k miles and found it to be quite clean. Honestly I havent had my car for a little while so I couldnt verify what it idles at, however I do remember it idling at about 750 rpms when I had it.
mvm062
Nov 30, 2020 09:00 AM
slowlifer
Sep 8, 2015 05:53 AM
dcardello
Sep 3, 2015 11:44 PM
