Do tower braces help squeaks / rattles?
Old Dec 29, 2000 | 06:36 PM
Bingo
I've got a FSTB and RSTB from my 4th gen -- I'll eventually put them on, but I was wondering if boxing the suspension helps frame rigidity enough to reduce / prevent squeaks and rattles? What have ya'll found so far?
Thanks,
Bingo
Old Dec 29, 2000 | 07:17 PM
y2kse's Avatar
No, they don't.
Old Dec 29, 2000 | 07:31 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Thanks,
Bingo
You stuck a 4th gen FTSB on a 5th gen? Those two braces have a totally different design. The 5th gens have arched braces while the 4th gens are straight. Make sure you check to see if you have clearance problems or not because there must be a reason on having arched 5th gen braces.
Old Dec 29, 2000 | 07:40 PM
got rice?'s Avatar
Re: No, they don't.
Originally posted by y2kse
Does the 2K Maxima have any squeeks/rattles?
When I slapped on the front and rear STBs on my Z, cowl shake was reduced; the chassis felt much tighter and stronger.
I just installed a <a href="http://www.eatricezone.com/miata/suspension/404540A.html">GReddy FSTB</a> and <a href="http://www.eatricezone.com/miata/suspension/404475A.html">Cusco front lower subframe brace </a>on the Miata.. huge difference. The Miata, due to the convertible design, doesn't have the same chassis structural and torsional rigidity as say.. a 2K Maxima, so the addition of any braces makes a noticeable difference.
Old Dec 30, 2000 | 02:35 AM
Bingo
Thanks,
Bingo
No, not yet... it seemed it would fit from a visual inspection, but apparently looks can be deceiving...
Old Dec 30, 2000 | 06:14 AM
y2kse's Avatar
Re: Re: No, they don't.
Sure does Phuong . . . both before and after I installed my FSTB and RSB.
user 11122324
42
Jul 18, 2022 03:35 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
Stagnet04
Sep 14, 2015 11:28 PM
SusieQQ
Sep 9, 2015 12:14 PM
