Do tower braces help squeaks / rattles?
Originally posted by Bingo
I've got a FSTB and RSTB from my 4th gen -- I'll eventually put them on, but I was wondering if boxing the suspension helps frame rigidity enough to reduce / prevent squeaks and rattles? What have ya'll found so far?
Thanks,
Bingo
Thanks,
Bingo
Re: No, they don't.
Originally posted by y2kse
When I slapped on the front and rear STBs on my Z, cowl shake was reduced; the chassis felt much tighter and stronger.
I just installed a <a href="http://www.eatricezone.com/miata/suspension/404540A.html">GReddy FSTB</a> and <a href="http://www.eatricezone.com/miata/suspension/404475A.html">Cusco front lower subframe brace </a>on the Miata.. huge difference. The Miata, due to the convertible design, doesn't have the same chassis structural and torsional rigidity as say.. a 2K Maxima, so the addition of any braces makes a noticeable difference.
Originally posted by Y2KevSE
You stuck a 4th gen FTSB on a 5th gen? Those two braces have a totally different design. The 5th gens have arched braces while the 4th gens are straight. Make sure you check to see if you have clearance problems or not because there must be a reason on having arched 5th gen braces.
Thanks,
Bingo
Thanks,
Bingo
Stagnet04
09-14-2015 11:28 PM
