Not impressed at all!
Well, Ive finally got my car back together and running. I installed an underdrive pulley, a WSP y-pipe, JWT cams and fixed exhaust studs. My car is now slower! How can this be? Timing is good, runs smooth, sounds good, but runs slower. WTF!!!!! Ill be calling Jim wolf tomorrow but hopefully someone knows something here too. Thanks for the help,
Dano
Dano
Re: Not impressed at all!
Dano
Dano
you're sure you got the timing belt on correctly.. they'll run and sound okay at idle, but will have almost NO power if you got one of the cams a tooth off on the timing...
Also, it could jsut be a break-in thing. be careful on the car with the new cams for a little while.. there is a break-in period..
Yeah my friend did his own timing belt on his eagle talon and it seemed to idle fine but it had a loss of power but then I took it apart and found that he didn't match all the timing marks correctly and then I did it for him and no problem and the power was restored.
What do you mean by slower? For example, you could get a high-end cam and low-end would suffer. BTW, Nismomaxt, you said you have a y-pipe. Do you have an intake, high flow cat, b-pipe, etc? If you don't have the whole exhaust done and cai (I'm assuming you do) then you aren't getting enough air in and out. That could certainly hurt.
How do you know it's slower? Is that an actual measurement or it's just 'feel' slower? Because our natural, biological 'sensors', so to speak, aren't designed to measure acceleration with any kind of precision. So maybe you simply have great expectation on how fast it's gonna be after all those work and $$, and the car is just not improve that much, though it may still be faster than it was before.
So you drive an auto
. Outside of boost or n2o there isn't much you can do to the VG at least NA wise. Given full bolt ons and cams+headwork an auto is looking around 150-158whp. Figure low-mid 15s with a high stall converter and weight reduction. You should really add n2o to the bolt ons. It would allow you to run low 14s on a 50-60 shot. Otherwise to be "fast" NA requires a motorswap and some chassic modification *sledgehammer*.
I have the greddy catback and the stillen intake. I have the cattman CAI but Im having some problems with the fit. I think Ive gained quite a bit after 3500 RPM but Ive lost quite a bit in the low end. Not sure if this is an improvement overall. Im looking into a Level 10 torque conv. but Ive already spent an awfull lot on this car. All in all Im happy with it but I really dont think the VG takes to mods as well as a lot of people here think it does. Ive done just about every minor mod. available and this car still isnt what Id call fast. Im a die hard Nissan fan but if you want speed..dont buy a GXE.
Not sure if the VG has adjustable valve lash...but
Dano
Dano
Did you adjust the valve lash for the new duration and lift of the cam?
JWT should have included the new specs with the cam.
When I got my cam for my 95 SI, I had to adjust the valve lash and use their upgraded computer for everything to work correctly. Keep in mind I only gained .2 in the 1/4 mile. Not that impressive.
Re: Not sure if the VG has adjustable valve lash...but
Originally posted by 5spd92SE
This question might not even be valid for the VG...
Re: Re: Not sure if the VG has adjustable valve lash...but
well how high have you revved the car since you installed the cams?
and just to know, what are the specs of the stage 1 cams anyways??
Cam break-in?
A few guys have been hinting at cam break-in, but...
I dont think improper cam break-in would cause this type of power "loss" that is described.
Proper cam break-in procedure:
http://www.jimcookperformance.com/Te...7cambreak.html
James92SE
142
Jan 2, 2024 09:23 AM
Dasmith
Sep 23, 2015 08:28 PM
