Can't buy the ECCS Relay. What's it called that parts dept will understand?
Hi guys, I need the ECCS relay for my 93 Max GXE. I've got a page from the service manual where it says E.C.C.S. RELAY but the local dealeship told me they do not know what I am talking about.
The one I am looking at is what connects the computer pin 59 to the battery power. What do I need to tell the dealership?
TIA,
Tarzan
Maxima 93 GXE Auto
TIA,
Tarzan
Maxima 93 GXE Auto
Re: Can't buy the ECCS Relay. What's it called that parts dept will understand?
TIA,
Tarzan
Maxima 93 GXE Auto
TIA,
Tarzan
Maxima 93 GXE Auto
or call courtesy..they can email u or fax a parts breakdown diagram and u can pick which u want.
Tell the shop/dealership it is the green fusebox relay. They will know for that is a known issue with all Nissan's.. This is interchangeable with the fuel pump relay, or, you can tell them you want a green fuel pump relay. It will work for I have interchanged my fuel pump with my eccs (testing out a hard start) with no issues noted
Abdul
Abdul
Re: Re: Can't buy the ECCS Relay. What's it called that parts dept will understand?
Oh, that's great. I think that the green relay does not do much in normal circumstance and I can turn them around safely.
Where exactly is the ECCS relay located? I know the green one is on the back (geen and orange relays on the bracked in the trunk).
Abdul
Abdul
ECCS relay location
It is bolted under the hood, on the inside fender wall, from the driver's side headlight. Pop up the black horizontal cover, it should be the first relay. This info should appy to both the VG/VE for I have both cars..but..don't hold me to it..
Abdul
Abdul
Re: ECCS relay location
Thank you all for your help! Got it.
Abdul
Abdul
Re: Re: Re: ECCS relay location
The pump safety relay from the trunk worked fine for me. Now I need to drive around for a few weeks and if the car does not stall then the problem is fixed. If it does then it's not the relay problem. Looks like I do not need to buy it anyway.
Originally posted by mykizism
i might have that relay for sale.. email me if your interested
Matt93SE
Apr 8, 2018 09:23 AM
ah2002
Mar 9, 2016 01:42 PM
