K&N Cone Intake leads to MAS failure?
Old Dec 10, 2002 | 07:38 AM
Ute's Avatar
Ute
K&N Cone Intake leads to MAF failure?
I just had my 100K tuneup, and when I picked my car up, the owner of the shop (a reputable joint I trust) warned me about my pop charger. He claims it can "burn out" my MAF, and I was better off in the long run without it. My question is this:
Does he know what he's talking about, or is he smoking? I for one have never heard of this problem, but I'm not a mechanic either. Anyone with experince or knowledge on this supposed problem? Thanks
Old Dec 10, 2002 | 07:39 AM
mzmtg's Avatar
Minister of Silly Walks
If you over-oil the filter, it can damage the MAF. If you oil it properly, you'll be fine.
Old Dec 10, 2002 | 07:47 AM
Jamsan's Avatar
exactly...just make sure you dont go overboard in re-oiling or else oil will start to seap into the MAF, rendering it dead
Old Dec 10, 2002 | 08:42 AM
Ute's Avatar
Ute
Thanks for the clarification. My mechanic was technically correct then, he just didn't tell me the entire reasoning. I'll keep close tabs on the oil amount, and continue to enjoy the benefits of my cone filter.
Old Dec 10, 2002 | 09:06 AM
Bluebird's Avatar
I am Roid Rage
Hoe often are we supposed to clean and oil these things?
Old Dec 10, 2002 | 09:23 AM
Eric L.'s Avatar
K&N's intervals are once every 50,000 miles for regular maintenance, and about half that if it is dusty. I'm **** about things like this, so I clean mine every 10,000 miles. The filter can be cleaned around 20 times total which is why K&N claims its "1 million mile" warranty.
When reoiling, make sure the filter is dry before spraying on the red oil. All you need is a light coat (if you see red, its enough). Don't spray that oil until the filter is all oozing and dripping. After I reoil my filter, I let it air out and then wipe up the excess oil before reinstalling into my car.
Old Dec 10, 2002 | 09:42 AM
Bluebird's Avatar
I am Roid Rage
Thanks Eric.
Old Dec 10, 2002 | 01:12 PM
Lime's Avatar
I usually let the wash stage dry for a half a day or a day before I oil.
Old Dec 10, 2002 | 01:53 PM
VeeTec's Avatar
I use to just replace mine around every 3-5K miles.
Once you clean the filter, it will never flow as well. The cotton frays.
Old Dec 10, 2002 | 01:56 PM
mzmtg's Avatar
You replaced a $40 filter every 5k miles? I cant afford to spend $240 per year on air filters...
I've had my K&N panel for about 145k miles and cleaned it too many times to count.
Old Dec 10, 2002 | 02:31 PM
Zero Gravity's Avatar
how do you know the MAF is ruined
Old Dec 10, 2002 | 04:37 PM
dgpfx's Avatar
i got one too. I have a k and n air filer. Jusyt got it cleaned last 3 weeks. I dont have the oil to clean it. Do they have k and n air filter cleaning foil at kragen. How much times do i clean it?
Old Dec 10, 2002 | 05:25 PM
95emeraldgxe's Avatar
your fuel economy will suck and your rpms wont go past 2500-3000rpm
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
