K&N Cone Intake leads to MAS failure?
K&N Cone Intake leads to MAF failure?
I just had my 100K tuneup, and when I picked my car up, the owner of the shop (a reputable joint I trust) warned me about my pop charger. He claims it can "burn out" my MAF, and I was better off in the long run without it. My question is this:
Does he know what he's talking about, or is he smoking? I for one have never heard of this problem, but I'm not a mechanic either. Anyone with experince or knowledge on this supposed problem? Thanks
Thanks for the clarification. My mechanic was technically correct then, he just didn't tell me the entire reasoning. I'll keep close tabs on the oil amount, and continue to enjoy the benefits of my cone filter.
Originally posted by Bluebird
Hoe often are we supposed to clean and oil these things?
When reoiling, make sure the filter is dry before spraying on the red oil. All you need is a light coat (if you see red, its enough). Don't spray that oil until the filter is all oozing and dripping. After I reoil my filter, I let it air out and then wipe up the excess oil before reinstalling into my car.
Originally posted by VeeTec
I use to just replace mine around every 3-5K miles.
Once you clean the filter, it will never flow as well. The cotton frays.
You replaced a $40 filter every 5k miles? I cant afford to spend $240 per year on air filters...
I've had my K&N panel for about 145k miles and cleaned it too many times to count.
maxima297
09-30-2015 03:32 PM
DC_Juggernaut
09-28-2015 04:07 PM
