Some good 300ZX caliper info.....
This is some general caliper info...not maxima swap specific.
Im going to do this conversion so I'm looking for all info.
I thought this would help explain the difference in the aluminum and iron calipers.....rotor thickness.....etc
http://importnut.net/300zxbrakeswap.htm
http://www.princeton.edu/~asad/zbrakes/
ZX Calipers on a G20:
http://www.conecrazy.com/project-g20/brakes.html
Basically some good pics of the calipers and stuff....
Part #'s
http://www.zilvia.net/installs/zbrakes/300zx.asp
Cheston's site has a write up as well.....
http://www.maximadriver.com/
PDM Racing.....Mostly for 240/Sylvia 300ZX brake coversion.....but you could buy the necessary parts here too I suppose.
http://www.pdm-racing.com/products/brakesz32.html
Another page..........its a Sylvia.........but again more info and good part numbers......There is also a link on this page detailing how to change out the pads on 300ZX calipers......
http://www.importcargarage.com/kings...gar/brakes.htm
Link to change pads.....
http://www.zhome.com/ZCMnL/PICS/Brak...BrakePads.html
Courtesy Nissans Z32 Brake parts page....
http://www.courtesyparts.com/z32_brakes.html
Here is a page detailing the 3000 GT VR-4 12.?? inch Rotor upgrade that can be done to ZX's........which will work on a Maxima as well. (providing you have wheel clearance for the larger diameter setup) Seems like alot of money for two brackets and some bolts and washers....
http://www.greggscustoms.com/300zx.htm
Hopefully these kind folks dont get PO'd at me whorin they're links!
Part #'s
thank you aaron
are ss brake lines have a different connector to the caliper..correct?
i will take pics tonight of our ss brake lines (sine i have a compete set sitting in my basement)
Originally posted by redmaxpa007
thank you aaron
thank you aaron
Aaron
Originally posted by Aaron95SE
Added more links to more good info.....
More part #'s.....
More Pics.....
And a page detailing how to change the pads out on ZX calipers....
More part #'s.....
More Pics.....
I'm just trying to get as much info together so when someone asks...
"Will 300ZX calipers work.......yada yada yada"
They will have a crap load of info available..........providing they use the search......
You know Jeff............you could add on to this when you try the ZX rear calipers.........since you have them............everything mounts the same right........its just a E-brake cable issue right......I do work Sheet Metal....and hand in hand with a Machine Shop.....(who will be the ones milling 3mm off my ZX rotors when I get em
once i try those rear calipers i will let everyone know... and you know this man...
Re: Some good 300ZX caliper info.....
some one is "supposidly" going to make a bracket cheaper.. *cough.. Matthel Ma...*cough.. cough
Re: Re: Some good 300ZX caliper info.....
Re: Re: Re: Some good 300ZX caliper info.....
Hehe.....I read that too.......That'd be sweet if he did. 3000GT rotors would be cool.....I'm trying to stay as stock/sleeper/stealth looking as I can. They might could be crammed under 16's
Re: Re: Re: Re: Some good 300ZX caliper info.....
yes, that would be nice.. and BTW your e-mails keep coming back to me with no response..
But they got Flat Screens!!
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
dvcamp
Sep 18, 2015 10:17 AM
sdotcarter
Sep 2, 2015 09:53 PM
