127 mph top speed?
Old Dec 23, 2002 | 02:59 AM
sebaxx's Avatar
127 mph top speed?
hi there...well im back of the freeway i was trying to find out how much my Max can go....and heres the results:
i run my car at 120 mhp in O/D off, when i consider almost red line in the odometer i change to O/D on to get more speed with change the gear...it results...my car go a little more fast...the speed i got was 127 mph.
I saw many guys that tells the maxima easy get more than 130 mph maybe my engine is old.....my max is 1995, and has 130,000 miles, what do you think? aaaa almost forgot i dont know why my max GXE doesnt have governor, and comes with bose stereo/cd, sunroof, etc..the only difference with gle is the leather seats.
what do you think about the top speed?????
Old Dec 23, 2002 | 03:41 AM
sebaxx's Avatar
forgot to tell you...
i forgot to tell you guys, the 127 was at 4200 rpms. There some guy to told here that we should put o/d on at 130mph to get easly 140, but i think if my car was 127mph with o/d on, for 15 seconds..it supposed to seems the top speed cause the car didnt get more fast.
Old Dec 23, 2002 | 05:35 AM
xarfox
the reason your GXE doesnt have a governor is prolly because you got the nicer one without the crappy tires, the cheapest max in 95 had to have govenor cuz it wasnt safe to go over 110
my max is 95 auto and i could only get it to 120
supposebly top speed is 144, but then again the engine is getting old
i tested this around 95k miles, i have 104 now and refuse to drive that fast any more, maybe i can get up there with a ypipe and cai
Old Dec 23, 2002 | 05:43 AM
Sprint's Avatar
he didn't get a nicer one.. he just got one with security and convience..
Old Dec 23, 2002 | 09:26 AM
JustTry's Avatar
Im surprised noone said anything yet- but how in the world did you get redline in the ODOmeter??? Madness, shear MADNESS! Sorry, i had to correct you, but the ol' odometer measures how many miles your car has driven/rolled/pushed/etc...
Old Dec 23, 2002 | 10:19 AM
xarfox
yea isn't it tachometer?
duh
Old Dec 23, 2002 | 12:08 PM
JamesAvery's Avatar
tru
duh
Old Dec 23, 2002 | 12:41 PM
NmexMAX's Avatar
dot dot dot ...
I got 181+K and still hit the higher rpms with O/D off, pulls like a charm. I like my VI
Old Dec 23, 2002 | 01:49 PM
sebaxx's Avatar
sorry about odometer...jejej is RPMS
You are right!!!!!!!!!!! i get 127 mph at 4200 rpms.
Old Dec 23, 2002 | 03:56 PM
Sprint's Avatar
Re: sorry about odometer...jejej is RPMS
yeah you got the auto version thats why...
Old Dec 23, 2002 | 04:40 PM
CaLSoNiC
Yeah, I belive that the manal transmissions can handle more speed. I think that someone said something on the .org that its also the settings that the automatics have in their electronics. Cuz, ive gone past 140 in my car, but didnt have a camera..
Old Dec 23, 2002 | 09:26 PM
Paonessa
it's 10 easy steps to stop the governor. it makes your check engine light stay on and if you check the codes If you check the codes you will get 0104 (Vehicle speed sensor fault) and 0504 (A/T control unit fault).
no one's ever comlained about a change in drivability
1.Disconnect negative battery terminal.
2.remove ECU cover from passenger side footwall.
3.Loosen bolt in center of main ECU connector.
4.Unplug main ECU connector.
5.Remove snap-on plastic cover from ECU connector.
6.Locate PINK wire with BLUE stripe. (this wire is located on the right half of the connector when plugged in)
7.Cut PINK/BLUE wire.
8.Reassemble ECU connection.
9.Reconnect negative battery terminal.
10.Drive 140mph.
Old Dec 23, 2002 | 09:33 PM
krbga's Avatar
strange...99SE Auto...
I was able to hit 135 last year.
with my 15x7 Ats CompLites. maybe I was actually going 127?
wish I had my Camera
Old Dec 23, 2002 | 09:48 PM
Minimalmaxima's Avatar
Re: strange...99SE Auto...
The fastest I have reached on flat land is 133 mph. Granted, I have always caught up to the traffic in front of me by the time I get to about 130, but I have always read on the org that the manuals are faster. To the dude who got over 140, was it flat land? Are you sure you're stock? Do you have mudflaps? How big are your wheels? What tire width and aspect ratio are your tires? Do you keep them at the specified pressure?
Old Dec 23, 2002 | 10:16 PM
CaLSoNiC
Mostly flat, at the time I was completly stock. I got a 5-speed SE. It took me a good 4-5 miles to do that though. This was posted a while back, but this person cheated.
Old Dec 24, 2002 | 05:50 AM
xarfox
Old Dec 24, 2002 | 06:29 AM
Sprint's Avatar
thanks for using hte pic of my dash.. no explain how i cheated
Old Dec 24, 2002 | 07:48 AM
Paonessa
I was told that only the gxe models are governed.
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
salty318
Sep 29, 2015 01:21 PM
Sep 27, 2015 08:37 AM
