Racing slicks..weight issue as well?
Hi all, I have a question about racing slicks..
A lot of people mount these on the stock front steelies, but are there any lighter OEM steel rims on other cars that will fit a 4th gen as well? Also, since you have slicks, would it be better for the rim to be lighter, or the stock weight is fine for traction? I know i could go with small aftermarket lightweight rims but it's a money issue.
Thanks,
Mario
Thanks,
Mario
Re: Racing slicks..weight issue as well?
Thanks,
Mario
Thanks,
Mario
I am in the process of doing the same thing but haven't found a cheap solution yet.
There are expensive solutions ie Hart's etc but I am not ready to give in yet. I also want a set for the rear to get rid of the weight there too, and some nice light skinny tires to go with them.
Re: Re: Racing slicks..weight issue as well?
Originally posted by Jime
The lighter you can go the better. However its not easy to get a light wheel without paying big bucks. The mazda millenia is nice and light at 11.5 lbs but its only 6" and most slicks require at least a 7".
Contrary to popular belief, wheel weight has nothing to do with traction, so don't make the mistake of thinking a lighter wheel makes for less traction, it doesn't.
Anyhow, Mazda Millenia wheels are very light but fairly narrow at only 6" wide. I know of at least 2 slicks that will fit on them though.
I run the BFG G-Force T/A drag radial in 225/50/15 on the stock steelies and they weigh in at 40 pounds total ... 2 lbs more than the stock tire sizes...but it works so I don't care...
My 205x45x15 Nitto 555r's weigh 17 lbs.
My 22x8x15 slicks weigh 11 lbs
Total of 30 lbs for racing but if I had 11.5 lb Millenia wheels the total would only be 22.5, but thats for this racing season.
Just have to find the wheels.
Hmmm maybe I should just lose 20 lbs, maybe I should do both. How about helium vs air in the tires?
Originally posted by Aaron92SE
Does anyone know if it's possible to fit 14" 5 lug wheels on my front?
I don't think I want to go any smaller now anyway, we have one track that has a rough return road and I bottom out all the time so its pretty low. Lowering springs did that mostly though.
I also have to get someone lift up on the front fender to get the jack under now when the 22" slicks are mounted, so I can't change tires myself anymore.
Mar 12, 2020 12:06 AM
BrandonCause
Sep 14, 2015 10:41 PM
