17s Vs Light weight 18s
Old Jan 8, 2003 | 10:28 AM
MaxSpeedSE's Avatar
Hey,
I have 17 inch Konig Monsoons that are 21 pounds i believe
If I buy light weight 18s, that are about 20 pounds..would that mean acceleration wise my car would be about the same..or would I be slower?
Old Jan 8, 2003 | 11:19 AM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
The tires will probably be heavier due to the stiffer sidewalls that you need, and you'll still have more weight at the outside which will give your wheels a higher moment of inertia. May not be a big difference, but it's probably not going to help your overall performance.
Old Jan 8, 2003 | 11:25 AM
5spd92SE's Avatar
Re: 17s Vs Light weight 18s
Originally posted by MaxSpeedSE
Hey,
You will also have a greater contact patch which will create more friction, thus slowing you down slightly.
Better cornering (tire dependent)? Yes.
Slower straight line performance? Slightly.
Old Jan 8, 2003 | 11:38 AM
MaxSpeedSE's Avatar
Re: Re: 17s Vs Light weight 18s
Both the rims are 17x7.5 and 18x7.5
Old Jan 8, 2003 | 12:32 PM
5spd92SE's Avatar
Re: Re: Re: 17s Vs Light weight 18s
What I should have said earlier:
If the overall diameter with the 18's and with new tires increases, you will have more tire contacting the pavement creating a larger contact patch than with the 17's, and like SteVTEC said, the moment of intertia will be greater.
I made the assumption that the overall diameter always increases with an increase in wheel size, which isnt always the case.
What tires are you going with? They will play a role in your performance #'s also.
Old Jan 8, 2003 | 12:47 PM
MaxSpeedSE's Avatar
Re: Re: Re: Re: 17s Vs Light weight 18s
Im really not sure....
What are my choices, and what would be the diffrence?
Sprint's Avatar
damn that sig is hot
Old Jan 8, 2003 | 02:33 PM
5spd92SE's Avatar
Re: Re: Re: Re: Re: 17s Vs Light weight 18s
You are going to have to be more specific on that one...
What climate do you live in? What will the car be used for?
How much (this is key) do you want to spend?
Etc, etc.
Narrow it down a bit, and then we can help you further.
Old Jan 8, 2003 | 03:58 PM
Frank Fontaine's Avatar
You have a full inch less sidewall and a full inch more rim. Rim is more dense than tire, in all cases if I'm not mistaken. Why the 18" rim would be lighter is an enigma, short of them costing a fortune.
I have 235/40-WR18's on 18x8's and I can honestly say they offer no performance benefits. But on a Maxima, that's not the reason to get them, it's looks.
Old Jan 8, 2003 | 04:31 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
yes it is
Old Jan 8, 2003 | 05:39 PM
MaxSpeedSE's Avatar
Re: Re: Re: Re: Re: Re: 17s Vs Light weight 18s
Etc, etc.
Im in Florida... and there going to be used for everyday driving, and your every weekend drag race..
price dosent matter becuase i get tires for free...and i want 18s becuase i plan to get boost in the future
Old Jan 8, 2003 | 06:02 PM
slimer's Avatar
Re: Re: Re: Re: Re: Re: Re: 17s Vs Light weight 18s
go with 18's, IMHO they look better. I dont think that ive ever heard of anyone getting 18's and wanted to go down to 17's, but i hear a lot of people w/ 17's wanting to go up.
Old Jan 8, 2003 | 07:40 PM
NYCe MaXiMa's Avatar
more mass further away from the middle of the wheel.. i guess they may slow you down tiny bit compared to those 17s..
but the difference won't be big..
the big difference in looks outweighs the minor difference in weight/performance... by a lot!
17s are even stock on Huyindais now..
I had 17 lb.. 17's and sold them, now i'm going to get some 18s, which are likely a good 7+ lbs heavier, each. I don't mind that much because they look so much better and I don't race, nor do I try to squeeze every bit of performance out of the car.
Old Jan 8, 2003 | 07:50 PM
MaxSpeedSE's Avatar
Thanks guys, very good points
Old Jan 8, 2003 | 08:04 PM
Conrad283's Avatar
I need a truck
you're just talking about her a$$ whats up
Old Jan 8, 2003 | 09:07 PM
95emeraldgxe's Avatar
i thout he was talking about the car you
DJLAX152
May 4, 2021 11:46 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
