what is everyones fuel pressure at idle
hi what is everyones fuel pressure with a v2 3.125 pulley.
im getting 30psi at idle and i haven't pay attention to the WOT fuel pressure cause im a b1tch and im scared to open it up.
hehehe oh i kind of drove it hard and checked my plugs and it was like a dark brownish color around the ring and the top of the ground strap was brown in color.
thanks
frank
oh by the way it drive beatiful im just a worry wart
thanks
frank
Re: what is everyones fuel pressure at idle
thanks
frank
thanks
frank
thanks everyone
yeah i kind of keep it on the dl just in case ish happens and it didn't go through.
but i just got a fuelpressure reading its at 30psi normal driving and at like 4-5k on the freeway it was hopeing abck and forth between like 60-70psi.
kevin hehehe thanks for the help.
dag on ething is i don't remeber this thing being as loud as it is on dennis car. is it cause the smaller pulley???
oh and the other thing i filled up gas yesterday on the 15th have 45miles on the tanks annnnnnnnnnnnnnnnd i droped about an 1/8 of a tank already. OMFG what a gas gustler.
Originally posted by Turbo95Max
i think fuel pressure at idle is suppose to be 36psi....thats what i seem to remember...
Yup, that's what mine was at. I had a V1 with the 3.125 pulley.
My fuel pressure at idle was at 34 psi (exactly on spec for a 4th gen) but increased to 40 psi when I installed a Walbro fuel pump.
The presence of a supercharger shouldn't change fuel pressure at idle, unless you have the Walbro pump or if you have your Hobbs switch disconnected so that your Vortech aux fuel pump is always on.
uhmmm i had a SARD fpr. left over from my nitrous kit. like they the shop took that off completly and ran everything to the FMU. shoud i put my stock fpr back on
So you only have the Vortech fmu and no other fpr? I didn't think the fmu did anything in non-boost situations. When you said you were getting 60-70 psi fuel pressure on the highway, was that with positive boost pressure or just when cruising?
my boost gague dosn't work yet. but yeah i was kind of gunning it probably at 60-70% throttle w/OD off. and it was boosting.
Originally posted by Craig Mack
I have the exact setup as you. Walbro and stock FPR and i'm at 40psi. Should we worry?
My fuel pressure at WOT is now at 48-50 psi (I'm still NA at present). I haven't checked my EGT at WOT yet, but I would expect it to be lower now, since at WOT the ECU reverts to a premapped injector pulse width. Since the ECU assumes that the fuel pressure is 43 psi at WOT, I am certainly running richer than before. Injector flow is proportional to the square of the fuel pressure, so if a stock Maxima is programmed for an AFR of 13 at WOT with 43 psi fuel pressure, then increasing the fuel pressure to 50 psi results in an AFR of about just over 12. (I calculated the AFR of 13 at WOT by assuming an AFR of 14.7 at idle when the fuel pressure is 34.) An AFR of 12.1 is too rich for a NA engine, but not too bad for a boosted engine.
In your situation (boosted, that is), since the base fuel pressure is raised from 34 psi to 40 psi, then your fuel pressure when boosting will be raised as well, if the formula provided by Vortech holds. So you are probably running a bit richer than otherwise. Dyno tuning or low EGTs will reveal if you are too rich.
Well I'm on the 3.33" pulley with the 6:1 disc. At WOT I peaked at 65ish PSI. According to Mardi and them, that is perfect. So only at idle do I run rich, which doesn't really concern me. Thanks for the writeup.
ok now that i notice it anything below 3k im at liek 28-30 psi and as i give the car gas my fuel pressure dosen't move.
when i go about 70% throttle and get int boost my fuel pressure goes to like the before mentioned:
4k 40-50psi
5k 50-60psi
6k im like at 70psi
i guess that is right im more worried about my 28-30 psi while driving normally. dosen't that seem low???
sould i put the stock fpr back in or does the fmu pretty much bypass the stock fpr.
oh and i am also running a walbao 255high flow so i am not using the aux fuel pump would that have something to do with the problem or is it noy a problem.
thanks for the help people
frank
4k 40-50psi
5k 50-60psi
6k im like at 70psi
frank
If you have the Sard, and your idle FP is low, you should be able to raise that with the Sard. It should be just a screw you turn
there is some variance in guages, so it's hard to be sure, but I would try to raise it to the 35 PSI level for safety's sake. It should be painless to do with the SARD.
4k 40-50psi
5k 50-60psi
6k im like at 70psi
frank
4k 40-50psi
5k 50-60psi
6k im like at 70psi
frank
like what goes where????
how do i tap the vacum hoses and how to hook up the fuel line.
thanks
ps: pics of the setups with a sard and how you guys connected it will help greatly.
frank
i'll take pics later 2nite if no one else does... getting the vacuum line is pretty easy, you just need to tap into the vacuum lines that you used for the bov, boost guage, all those goodies... go to autozone and get a vacuum t fitting apppropriate for your setup. btw, when you get fuel line, you need high pressure fuel line, NOT just regular fuel line.
Sexima, if you can do a write up on it, I will sticky it in this forum. Thanks, in advance.
Del
let me take a poke at this seximagtr can you comfirm???
so it goes fuel rail out into the side port of the SARD fpr.
then
bottom port of the SARD fpr into the upper port on the FMU.
then
bottom port of the FMU back to the fuel retun line on the motor.
vacuum lines get tapped into the rest of the vacuum lines from the the boost gague which the FMU is tapped into which the BOV is tapped into
CORRECT????????
then
then
CORRECT????????
noooo... fuel rail goes to the BOTTEM of the sard. the side port is for the INLET. the inlet connects to the OUTLET of the fmu. I'm still at work, but i should have pics up in about 4 or 5 hrs when i get off...
There is only one adjustment for the SARD FPR which affects both idle and WOT fuel pressure. In order to keep the Walbro in check, I adjusted the SARD to get N/A 43psi at WOT, and as a result my idle fuel pressure dropped down to 30psi. I haven't noticed or felt anything strange, and last time I checked, my plugs were okay.
In preparation for my SC install, I put on the B&M fuel pressure gauge inline from filter to hose leading to FPR...
at idle ... 44 psi... revs make it jump but I have not done any tuning...
44 psi at idle seems WAY too rich and should explain my exhaust looking the way it does and mpg being so low...I am going to tinker more later but thought I would throw that out there.
you have a walbaro pump right????/
do you have a FPR to tune the fuel pressure back to stock???
you take that picture with night vision goggles?No, Frank I do not have a fpr and opted not to get one before the SC purchase...I really am considering not running the aux pump if it makes me that much more prone to too-hi pressure and getting something like the Cartech or similar...I really rather would not do so as I want to make certain all the SC parts are operable as described.
fastcarny
Oct 6, 2015 10:42 AM
