3 options of Motors....help decide
Old Jan 20, 2003 | 12:21 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
ok trying to decide what to do, now that TurboMax needs a new motor im trying to decide what to do...help me please...
Option 1
stock motor, turbo, stock ECU, cartech FMU stock injectors
Option 2
stock motor, turbo, JWT ECU, 300ZX injectors
Option 3
VQ30DET motor, turbo, JWT ECU, 300ZX injectors
i dunno!!!
option 1 would give more power over option 2. Option 3 would prolly get the most power but more costly and time consuming
regardless of options, i think i will do a VQ35DET project sometime in the future
THANKS!
Old Jan 20, 2003 | 06:36 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
For now, option 1.
Old Jan 20, 2003 | 06:59 AM
MardiGrasMax's Avatar
Option 4
Stock Motor, Turbo, Stock ECU, 370cc Inj, Vortech FMU w/3:1 disc, J&S Safeguard and you do have an S-AFC right?
Old Jan 20, 2003 | 11:47 AM
Turbo95Max's Avatar
no option #4
no more options noOOoooOoOOO...anywyas uhhh they not open today so i got 1 more day to decide.
Old Jan 20, 2003 | 01:59 PM
TILLEYS99's Avatar
Lives in a 11sec maxima
The VQ30DET has 370cc injectors so you wont need the 300zx ones.
Old Jan 20, 2003 | 02:35 PM
Turbo95Max's Avatar
thats only if you can get me a VQ30DET motor....rite???? heeh
Old Jan 20, 2003 | 05:48 PM
The 300zxtt injectors are 370cc
Old Jan 20, 2003 | 06:08 PM
turbo97SE's Avatar
What's wrong with Arias pistons? Me wanna get some soon! You should just go straight for "stock" VQ35DET swap!
Old Jan 20, 2003 | 07:23 PM
tampamax's Avatar
Originally posted by MardiGrasMax
Option 4
Mardi suggested a great combo...its affordable,flexible,and probably provides the most margin for error without catostrophic(msp?) failure. Trust me when I say that unless you are polishing someone bizzallz at JWT then it will be more of a waste of time, effort, and money. If none of this appeals to you then you could just modify option 1 to include a set of upgraded injectors. But really what do I know.
P.S. Tilley, as soon as my motor takes a crap on me i'll be hitting you up for a turbo....
Old Jan 21, 2003 | 01:16 AM
Turbo95Max's Avatar
why would i need to polish someones ballz at JWT? i dont get it....why waste of time effort and money? wouldnt option 1 with upgraded injectors basically be option 2? oh well.....stock motor is gonna go in, juss gotta decide what else to do.
Old Jan 22, 2003 | 12:13 AM
Nismo87SE's Avatar
Re: 3 options of Motors....help decide
Option 1
depending on the turbo used, won't the stock injectors be way to small? At 4 bar fuel psi the 259cc injectors should be good for maybe 260-290hp @ 90% DC (I'm sure you know this already ).
Option 2
If you aren't going for max power, this might be the best alternative. Their turbo program for the SR20 and VG30 can't be beat for those who don't like to tune. I've personally driven a turbo se-r with that same setup as option 2. The car had better driveability than my se-r LOL.
Option 3
The DET should come with 370cc injectors. Hell if you could get the DET ECU you could use that. However you might be stuck with a 109mph speed limiter. Since you need a new motor get a DET and swap over all your USDM sensors and it should be fine. Besides the DET might have beefier internals than a DE would. Well at least that is the case for the SR20s and VG30s.
Cliff notes: Get the DET period.
Old Jan 22, 2003 | 05:55 AM
TILLEYS99's Avatar
Its a little more work than swapping sensors the block, front and rear timing cover are useless in a maxima.
Old Jan 24, 2003 | 12:25 AM
Nismo87SE's Avatar
Is the DET the same block or is it a different block? For the SR20DET the avenier/bluebird is basically the same as the SR20DE. However the GTiR DET has a slightly different cylinder head, ITBs, beefier crank/rod bearings. Also when you say rear timing covers are you refering to the cover for the left cylinder head + bank?
Old Jan 24, 2003 | 08:05 AM
mtrai760's Avatar
'Trynna' is not a word
the DET uses a different block
Old Jan 25, 2003 | 09:20 AM
mAdD MAX's Avatar
What happened to that built motor you had already built up? The one that caused a lot of problems but ended up working in the end?
I was really excited about that engine!
Old Jan 26, 2003 | 12:08 AM
Turbo95Max's Avatar
its blown.....heeh
Old Jan 26, 2003 | 12:53 PM
mAdD MAX's Avatar
Oh.
That sucks. How much power were you pushing?
TallTom
57
Oct 14, 2025 05:16 PM
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
