3 options of Motors....help decide
Turtle turtle... Moderator
ok trying to decide what to do, now that TurboMax needs a new motor im trying to decide what to do...help me please...
Option 1
stock motor, turbo, stock ECU, cartech FMU stock injectors
Option 2
stock motor, turbo, JWT ECU, 300ZX injectors
Option 3
VQ30DET motor, turbo, JWT ECU, 300ZX injectors
i dunno!!!
option 1 would give more power over option 2. Option 3 would prolly get the most power but more costly and time consuming
regardless of options, i think i will do a VQ35DET project sometime in the future
THANKS!
Option 1
Option 2
Option 3
i dunno!!!
THANKS!
Originally posted by MardiGrasMax
Option 4
Stock Motor, Turbo, Stock ECU, 370cc Inj, Vortech FMU w/3:1 disc, J&S Safeguard and you do have an S-AFC right?
Option 4
P.S. Tilley, as soon as my motor takes a crap on me i'll be hitting you up for a turbo....
Originally posted by tampamax
Mardi suggested a great combo...its affordable,flexible,and probably provides the most margin for error without catostrophic(msp?) failure. Trust me when I say that unless you are polishing someone bizzallz at JWT then it will be more of a waste of time, effort, and money. If none of this appeals to you then you could just modify option 1 to include a set of upgraded injectors. But really what do I know.
Re: 3 options of Motors....help decide
Option 1
Option 1
Option 2
Option 3
Cliff notes: Get the DET period.
Is the DET the same block or is it a different block? For the SR20DET the avenier/bluebird is basically the same as the SR20DE. However the GTiR DET has a slightly different cylinder head, ITBs, beefier crank/rod bearings. Also when you say rear timing covers are you refering to the cover for the left cylinder head + bank?
Originally posted by TILLEYS99
Its a little more work than swapping sensors the block, front and rear timing cover are useless in a maxima.
the DET uses a different block
Originally posted by mAdD MAX
What happened to that built motor you had already built up? The one that caused a lot of problems but ended up working in the end?
I was really excited about that engine!
TallTom
50
07-08-2022 09:54 AM
tarun900
19
12-20-2021 06:57 PM
06-06-2017 02:01 PM
