How noticeable is HLSD in everyday driving?
I'm having a helluva time finding a 2K3 the way I want it with HLSD. There is one a ways away from me that is what I want, but without HLSD. Do you even know it's there unless you're stomping on it? Would most of you still have a 6 sp w/o HLSD over an auto? Need to move quickly, but may be up a creek.
Re: How noticeable is HLSD in everyday driving?
Re: Re: How noticeable is HLSD in everyday driving?
Originally posted by vito1281
If you do a quick search, you'll see that this EXACT same topic has been discussed. To summarize, however, NO, you will not feel it in everyday driving unless you're stomping on the gas as you're cornering. Hope that helps.
Re: Re: Re: How noticeable is HLSD in everyday driving?
Originally posted by jjs
Not sure I agree with this statement. It helps also in wet conditions, and loose road surfaces. I know I would not want to be without the VLSD in my AE.
So in those cases, it would help by locking up the slipping wheel and spinning both wheels at the same power (i.e. distribute the power according to slippage).
. . . To summarize, however, NO, you will not feel it in everyday driving unless you're stomping on the gas as you're cornering.
Norm
I have a 6spd w/o the HLSD...
Yeah, I wish I had it....but I bought my car off the lot on a deal..so I settled....
It's not too bad not having it...makes for some interesting driving.
The max puts so much power down....not sure why the HLSD isn't standard.
buying an auto should not be an option...if so, go buy a camry/accord...save some $$ in the long run.
I get by w/o it...no regrets...but it would be a bonus to have!
Originally posted by Norm Peterson
Actually you might feel it under any circumstances in which the two front wheels have significantly unequal grip. In addition to feeding in throttle while cornering, there are any number of split-mu situations that you are likely to run into that will make the HLSD re-apportion torque under acceleration. Bare pavement not worse than damp under the driver's side and standing water/sand/gravel/snow/slush/ice/wet leaves/wet road paint under the passenger side come to mind . . .
Norm
Norm
I have the HLSD and STILL seem to spin my tires when taking off fast. Is it working or what? If it is, OMFG you need it!
Re: Re: Re: Re: How noticeable is HLSD in everyday driving?
Originally posted by spta97
Norm,
Norm,
The big problem here are tires that come with our car. They give no grip at all.
I don't think HLSD will help that much in snow or ice. Maybe a little.
Re: Re: Re: Re: Re: How noticeable is HLSD in everyday driving?
The advantage in snow/ice is when one side has even slightly more grip than the other. That's probably the usual case, as I doubt that the static front corner weights are equal except under some very specific loading conditions involving individual passenger weights and where they are sitting.
Norm
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
