Clutch fluid leaking.
just follow the lines
start at the clutch master cylinder, then it goes down and across the top of the tranny to the clutch slave cylinder which is right above the starter and pushes on the shift fork
if you cant find anything there, look up high at the base of the clutch pedal and see if it's leaking inside the cabin
it's a pretty simple hydraulic system so it shouldn't be too hard to track down
What is it leaking from? The only thing up there is the clutch master cylinder. So the logical conclusion is to replace the clutch master cylinder. How do I do that? Look for my post about repair info in the permanent posts on the top of this section.
Originally posted by Aqno
I've been having this same problem. It appears the leak IS inside the cabin at the base of the clutch pedal! What do I do next? Sorry for asking if its already been answered, but I couldn't find anything else when searching the forum! Thanks!
Mar 12, 2020 12:06 AM
Need help
23
Oct 2, 2015 08:56 AM
carlosvq30
Sep 26, 2015 09:44 AM
