healp please listen......my SC need advice
ok here it is____
http://fastforward.lchu.net/Frank-Super-Charge.wmv
to rebuild - or - not to rebuild
Re: healp please listen......my SC need advice
Originally posted by jdmmax
ok here it is____
ok here it is____
wtf was that
sounded like my water pump when it went out on me 2 yrs back !
Originally posted by robocop199
i think vortech gets around $500-600 for the rebuild, there's a few people on the .org that have sent their's back
Lets quit giving people bum scoop. Its going to cost you between $340-$359 that includes the rebuild and shipping back to you give or take a few dollars so relax.
WTF?! Sounds normal to me, at least me and Hookedup98SE sounds just like that the day of install. Did it sound like that the day you started it? Some guys said it was normal, and I did hear worse than that on someone's car I think it was BlackCat's blower, not sure.
-Ben
-Ben
-Ben
-Ben
you got that wiers lose sound to your blower???? like you can here the wistle in the backround but the main sound you hear is the sound im worried about.
I was talking aobut the loud grinding sound that I thought myself was problem as well, but was the same sound on Hookedup98SE's blower and everyone said thats normal. BlackCat's I think, had an inconsistent grinding sound where it would get loud and soft. Is that the sound your referring to? Unless its just the sound clip, I'm hearing a little bit of a hollow drongin sound, like when your listening through a long pipe or something.
heheh yeah i have that dronning sound to in the morning when i start up my car its pretty loud.. of course not as loud.
Originally posted by WizzaMax
sounds bad...hope you get it fixed
I need to listen to it, at this time my computer does not have a sound card. Only the computer at home, Ill let you know if my blower sounds like yours. I know this much my blower is pretty loud specially with the CAI.
-Ben
-Ben
Jaime at Vortech said my bearings had started to go on me after they inspected it.
The rebuild made all the difference. It now has this cool jet-like whine/whistle that I've not had previously.
Rebuild cost me $363.95
oh damn
forgot i have a v2 w/3.125 pulley.
and uhmmm it sounds that bad huh?????
anyone know about how much this is gonna set me back.
oh damn
Before you start tearing down the supercharger do this:
I posted in an old thread that I've discovered that the belt between the 3.33" pulley and the tensioner pulley would vibrate and this causes that nasty rattle noise in the blower. This never happened with the stock 3.60" pulley. I had to fiddle several times with the belt tension to find that sweet spot between excessive rattle and belt slip. At the moment I've still have a slight rattle whenever the idle speed dips to 650/700rpm but I've managed to almost completely stop belt slippage noise.
Originally posted by BlackCat
I missed reading what pulley size you've got.
Hmm, one day I'm going to have to adjust my belt tension I guess. I have the 3.33" pulley and Hookedup98SE has the 3.6" and they sound exactly similar, except his is moving at a slower rate because my idle speed happens to be higher. I'll look into it though. So its the belt tension eh?
Tightening the belt would only make the noise worse and overtightening will cause premature failing of the blower bearings. I believe I did this to my blower. Loosen the belt and the rattle would go away but then you'd get belt slippage on cold mornings. All I can say is that the supercharger prefers a warmer climate!
