healp please listen......my SC need advice
Old Jan 26, 2003 | 11:31 PM
jdmmax's Avatar
ok here it is____
http://fastforward.lchu.net/Frank-Super-Charge.wmv
to rebuild - or - not to rebuild
Old Jan 27, 2003 | 12:30 AM
GoldenGlory
Re: healp please listen......my SC need advice
Originally posted by jdmmax
ok here it is____
wtf was that
sounded like my water pump when it went out on me 2 yrs back !
Old Jan 27, 2003 | 05:40 AM
Cumalot's Avatar
Hm...doesn't sound too healthy.
Old Jan 27, 2003 | 06:51 AM
BlackCat's Avatar
RIP '98 Maxima SE
Its your bearings. Time to send it in to Vortech.
Old Jan 27, 2003 | 09:49 AM
jdmmax's Avatar
oh damn
forgot i have a v2 w/3.125 pulley.
and uhmmm it sounds that bad huh?????
anyone know about how much this is gonna set me back.
Old Jan 27, 2003 | 10:22 AM
robocop199's Avatar
i think vortech gets around $500-600 for the rebuild, there's a few people on the .org that have sent their's back
Old Jan 27, 2003 | 10:41 AM
JAY25's Avatar
Lets quit giving people bum scoop. Its going to cost you between $340-$359 that includes the rebuild and shipping back to you give or take a few dollars so relax.
Old Jan 27, 2003 | 10:58 AM
jdmmax's Avatar
so you guys think im up for a rebuild huh????/
Old Jan 27, 2003 | 11:05 AM
BippuBenji's Avatar
WTF?! Sounds normal to me, at least me and Hookedup98SE sounds just like that the day of install. Did it sound like that the day you started it? Some guys said it was normal, and I did hear worse than that on someone's car I think it was BlackCat's blower, not sure.
-Ben
Old Jan 27, 2003 | 11:09 AM
jdmmax's Avatar
-Ben
you got that wiers lose sound to your blower???? like you can here the wistle in the backround but the main sound you hear is the sound im worried about.
Old Jan 27, 2003 | 11:43 AM
BippuBenji's Avatar
I was talking about the loud grinding sound that I thought myself was problem as well, but was the same sound on Hookedup98SE's blower and everyone said thats normal. BlackCat's I think, had an inconsistent grinding sound where it would get loud and soft. Is that the sound your referring to? Unless its just the sound clip, I'm hearing a little bit of a hollow droning sound, like when your listening through a long pipe or something.
Old Jan 27, 2003 | 11:51 AM
jdmmax's Avatar
I was talking aobut the loud grinding sound that I thought myself was problem as well, but was the same sound on Hookedup98SE's blower and everyone said thats normal. BlackCat's I think, had an inconsistent grinding sound where it would get loud and soft. Is that the sound your referring to? Unless its just the sound clip, I'm hearing a little bit of a hollow drongin sound, like when your listening through a long pipe or something.
heheh yeah i have that dronning sound to in the morning when i start up my car its pretty loud.. of course not as loud.
Old Jan 27, 2003 | 12:09 PM
WizzaMax's Avatar
sounds bad...hope you get it fixed
Old Jan 27, 2003 | 01:23 PM
JAY25's Avatar
I need to listen to it, at this time my computer does not have a sound card. Only the computer at home, Ill let you know if my blower sounds like yours. I know this much my blower is pretty loud specially with the CAI.
Old Jan 27, 2003 | 01:32 PM
jdmmax's Avatar
well the rattling like sound you guys are hearing those who listened to the clip goes away at 1700 rpm.
Old Jan 27, 2003 | 01:40 PM
BlackCat's Avatar
RIP '98 Maxima SE
-Ben
Back in November my V2 sounded just like that. The noise got worse and worse. At first it showed up while at idle at a stoplight and then a little while later it showed up the few seconds when first starting the car up in the morning. Iansw posted my sound file for me and it sounded sick.
Jaime at Vortech said my bearings had started to go on me after they inspected it.
The rebuild made all the difference. It now has this cool jet-like whine/whistle that I've not had previously.
Rebuild cost me $363.95
Old Jan 27, 2003 | 02:24 PM
BlackCat's Avatar
RIP '98 Maxima SE
oh damn
I missed reading what pulley size you've got.
Before you start tearing down the supercharger do this:
I posted in an old thread that I've discovered that the belt between the 3.33" pulley and the tensioner pulley would vibrate and this causes that nasty rattle noise in the blower. This never happened with the stock 3.60" pulley. I had to fiddle several times with the belt tension to find that sweet spot between excessive rattle and belt slip. At the moment I've still have a slight rattle whenever the idle speed dips to 650/700rpm but I've managed to almost completely stop belt slippage noise.
Old Jan 27, 2003 | 09:15 PM
GoldenGlory
i have a book of notes from all ur guys..
thanx for all the info/and tips !
Old Jan 28, 2003 | 12:56 AM
BippuBenji's Avatar
Hmm, one day I'm going to have to adjust my belt tension I guess. I have the 3.33" pulley and Hookedup98SE has the 3.6" and they sound exactly similar, except his is moving at a slower rate because my idle speed happens to be higher. I'll look into it though. So its the belt tension eh?
Old Jan 28, 2003 | 08:17 AM
BlackCat's Avatar
RIP '98 Maxima SE
I've been fiddling also with the idle speed lately. I find that the noise isn't there at 800rpm or higher. After the car is warmed up in the morning after a little drive the idle at the stoplight would dip to 650-700rpm and the blower will rattle slightly. So far, disconnecting that throttle sensor and playing with the idle speed adjustor has upped my idle speed but now I get an odd up and down idle speed (like surging) instead of a level and consistant speed.
Tightening the belt would only make the noise worse and overtightening will cause premature failing of the blower bearings. I believe I did this to my blower. Loosen the belt and the rattle would go away but then you'd get belt slippage on cold mornings. All I can say is that the supercharger prefers a warmer climate!
Mahmuth
Aug 16, 2024 08:23 PM
gigabyte
Jan 6, 2017 06:05 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
dshinn
Sep 26, 2015 08:07 PM
