Altinator...if you ever had a Alt. prob. check this
Old Feb 22, 2003 | 10:29 PM
ChrisCheezer's Avatar
(my problem) Ok, when the car is at a stop random things will shutoff/dim (my headunit mostly) all the dash lights dim. when this happends im fuked... because, as soon as i turn the car off it will not start up again, unless i get a jump-start. then it starts right up
-my batt. is 5 months old and its 900cca (tested 100% charge)
-when im at a stop and rev the enigne, all the dash lights glow brighter.
what do you ppl think... electrical short? or altinator,
..do you need more info
, i hope some one can give me there 2 cents before i go the shop tomorrow
peace
Old Feb 22, 2003 | 10:40 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
alternator
Old Feb 22, 2003 | 10:42 PM
Maximan190's Avatar
does the car hold an unsteady idle also? I had an alt. problem and i had to keep it reved up in neutral also at stoplights so i wouldnt stall in the instersection
Old Feb 23, 2003 | 09:21 AM
Matt93SE's Avatar
STFU n00b!
1. It's alternator
2. Check your battery cables and all the connections on them. if the battery is staying charged, then it sounds mor elike you're got a wiring problem. the factory terminals tend to corrode and fall apart after several years. replace them and see where it goes from there.
Old Feb 23, 2003 | 09:43 AM
JD's Avatar
JD
Like Matt said, battery terminals have caused this before.
Don't forget something simple like the belt either, could be slipping some - had the same results one time.
Also, check plug in connections. I had an alternator installed, few months later was experiencing problems intermittently. Turned out the plug in to the alternator was lose not making a great connection.
Old Feb 23, 2003 | 10:23 AM
rcy's Avatar
rcy
Re: Altinator...if you ever had a Alt. prob. check this
peace
Voltage Regulator possibly - it's built into the alternator, so unless you know or feel like poking around in the innards of the alternator, you'll need to install a whole new alternator.
maxinout93
Oct 31, 2015 02:04 AM
magiconthetire
Oct 26, 2015 09:03 PM
salty318
Sep 29, 2015 01:21 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
