Car won't start after neon install....help (long)
I had a set of neons under the dash that someone else installed for me. I was trying to install some under the seats now. I reached the place that was tapped for power by the old neons underneath the steering column. I had the old neons on to help me see. So I tied the new neons on. I unscrewed the metal plate (the one you would undo to take down the steering column) to use as a ground. But when I took it off the metal plate touched the area that was tapped by the old neons and they cut off. Now everything that was on that harness has no power...radio, acc, starter, and the neons. I have no idea what happened, maybe when the metal touched the wire tap it used me as a ground and shorted.
Any suggestion, thanx in advance for the help - Chad
Re: Car won't start after neon install....help (long)
Look at the fuse block under the hood. If I recall correctly.... There are some fuses with a clear top. Check each one. It will be very noticable if one is blown.
Found it...thanks guys. Its one of the bigger fuses 30A. Can I get those at autozone or advanced....or is it something i have to go to the dealer for.
THanks - CHad
THanks - CHad
If it's one of the fuse blocks (fusible links) under the hood, it may be easier just to goto dealer. Of course you'll pay out yer ***, but it cuts down on going store to store and having someone match it up.
Originally posted by 95emeraldgxe
wouldnt radio shack carry fuses like that?
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
BobMax
Aug 15, 2015 12:35 PM
