tranny whine, anyone else have this?
Old Jan 10, 2001 | 09:55 PM
flyry110's Avatar
hey, my tranny whines in 1st gear, and whines a little bit in other gears till it's warmed up. the fluid is good, i changed it about 2,000 miles ago, and it's topped off. any ideas?
Old Jan 11, 2001 | 09:08 AM
RosenKen's Avatar
same here, and I have Redline fluid. Mine only whines in 1st gear. Others have this too.
Old Jan 11, 2001 | 11:04 AM
davis449
If it's a quiet whine in 1st gear and maybe a little bit in the other gears then your tranny is fine. If it's real loud that means the gears it's real loud in are wearing out. I had both my 1st and 2nd gears replaced and now the whine is much quieter.
Old Jan 11, 2001 | 11:06 AM
Chris Gregg's Avatar
Get Off My Lawn
When I first bought my 89 5sp it whined. Guy told me it was the main shaft in the tranny and just needed to be replaced. It whined bad! I took it to a shop and ended up having to replace it. Can you say $2,000+ for a USED tranny and install with clutch!? Ouch! Anyway, take it to a tranny shop, it may be the main shaft. Best way to tell is if you put it in neutral, release the clutch. If it whines, it's the main shaft, this is the only part of the tranny that turns in neutral.
Old Jan 11, 2001 | 02:08 PM
Isaacm's Avatar
O/D Whine
Mine only whines in O/D when it's cold, and it's not very loud. If the radio is on, I can't even hear it. Does anyone think I have to worry about this?
Old Jan 11, 2001 | 02:47 PM
Get Off My Lawn
O/D? Uhm, If I'm not mistaken, everyone is refering to manual trannies? If your auto whines, my first thought would be tires. In O/D the rpm's drop (engine gets quiter) and your at a higher speed, so tires may be the issue here.
Old Jan 11, 2001 | 06:36 PM
flyry110's Avatar
yeah, it kinda whines in all the gears. if i have the radio on at all i can't hear it. I wasn't sure if it was normal or not. it's just enough that with the radio on at a talking volume, i can JUST hear it. if i move the stick around it changes a little too.
MaxStock
Dec 5, 2016 05:19 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
homewrecker
Sep 24, 2015 07:01 PM
pktaske
Sep 4, 2015 08:40 AM
