having a hell of a time getting my corner lamps out.help!
Ok, I'm not dumb and I can follow directions and have done everything on them but I cant get my corner lamps out for anything. I am not sure what I'm exactly looking for that is a ball and socket. I have done everything and tried getting a flat head in every damn spot it will fit. Can someone help or even have a pic of what I'm suppose to be looking for. You think that after 4 years of a good college education I could figure this out!
Max99
Max99
Re: having a hell of a time getting my corner lamps out.help!
Max99
Max99
I almost did that from frustration but held back when I thought of the money I would be spending to replace a two broken corner lamps.
Max99
Max99
-fnny
Max99
Max99
spray WD-40 in there first, let it sit for a couple of minutes,then rock it side to side, then wedge the screwdriver in there, and twist.
maybe it was a bad idea, but i took a big wrench and wedged it in there. I found that the larger object I used the easier it came out (i've taken them off a couple times).
Of course, that WD-40 idea is a really good idea. I wish I had thought of that. I didn't break anything, just bent some plastic back there, but nothing that affected anything.
good luck
BlueBOB
good luck
BlueBOB
sigh..don't we all have problems with this one. theres about 129487125981623591865912 threads on this
my right side one comes out loose goose, my left one is tight.
the **** just goes into the hole and doesnt want to come back out without a little lubrication.
i should use some wd40 next time. i cracked the end off too. nothing a little crazy glue couldnt fix.
Originally posted by ReichMax97
You talking about the corner lights, or the side marker lens?
03VQMAX
Oct 2, 2016 09:36 AM
MatthewsMaxima
Sep 11, 2015 03:21 AM
