ECU daignose: 0707 + 0304... need help!
aite so i did a ECU decode and i got 0707 (Rear Heated O2 sensor) + 0304 (knock sensor)... should i change them? i haven't been doin any agressive driving lately, is it essential to change it? where can i get quality and cheap parts from? cuz i don't wanna go to the dealership... please help me.
Re: ECU daignose: 0707 + 0304... need help!
Re: Re: ECU daignose: 0707 + 0304... need help!
Originally posted by CystumMax
change your knock sensor, but your o2 sensor take out and clean it with some gasoline. and put it back in usally it works. whats your cal milege.
Also, what a lot of experienced Maxima owners have noticed is that the knock sensor code usually doesn't mean the knock sensor has failed. I believe they call it a shadow code or something like that. Try cleaning the O2 sensor first, reset code. See if the CES light comes on again.
Re: Re: Re: ECU daignose: 0707 + 0304... need help!
where can i get cheap and quality knock sensor besides from the dealership?
I bought mine from expressautoparts.com last month for $107.xx shipped. If you clean out your 02 sensor and you still have a KS code then I suggest you get it from them. They are the cheapest I found. The only code I pulled was 0304, even after resetting my ecu several times. So I just went ahead and bought it, car feels better now. No more codes. One thing, when I was looking at my stock sensor(had small cracks on it) and the new Bosch sensor, they looked identical. Every #, word, and marking are the same. I know some of our oem sensors are Bosch, maybe this one is too.
Originally posted by deezo
http://forums.maxima.org/showthread.php?threadid=104931
From my limited experience, you should clean the O2 sensor, then replace if necessary.
If you get the 0304 code by itself is the only time you should replace the KS. Most likely when you get the O2 sensor repaired, the 0304 code will dissapear at the same time.
If you lose the O2 code and STILL get the 0304, then replace the KS.
But a KS Code with an O2 code probably means only the O2 sensor is bad, not the KS.
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Dasmith
Sep 23, 2015 08:28 PM
QueensMAX
Sep 15, 2015 04:14 AM
