bulb out in tail light
anyone know the number for the bulb in the tail light? i assume there are 2 different one, cause when the lights are on at night, the rear brake light is out. but when i put on my brake, both taillights light up. how hard is it to replace? thanks
Jonathan Marsh
2kmax
Jonathan Marsh
2kmax
its just a double filament bulb w/ one of the filaments burnt out...really really easy to replace...just remove the little screw things in the trunk and bend the black fabric material just enough so you can unscrew the bulb...then just pop it out and thats it
Hi Guys, I am having this same problem in my rear tail light. Where would be the best place to get another one so I can replace it. It is very annoying knowing that it is'nt working properly plus im going to disneyland tomorrow morning. Any help would be greatly appreciated. Thanx.
any auto store should have the bulbs. do what mr.burner said.
ummm...
if you want OEM, walmart has the sylvania bulb that is an exact match (unless you want to replace both). I've had the bulbs go out in both the max and the PF. sucks.. at least they are cheap to replace.
Originally posted by max2001se
Hey MrBurner, did you end up selling your max?? If so what did you replace it with??
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxima30
Sep 7, 2015 06:13 PM
