Porting Polishing/honing intake manifold
just a quick question guys, im wondering if porting/polishing or honing the IM would yeld any gains at all... J&M High Tech here in town can do it and they do it well. There working on a friend of mines integra gsr right now porting and polishing the head and a 3 angle valve body job and a few other things...
Would this help the max in any way or would this hurt my baby????
BTW im waiting on all my presents to come.... springs, shocks, Y & B pipes and pully(but dont know what pully to get yet)
Word has it that it won't do much for NA but if your boosted it will help a lot. After doing some reading on manifold design the prior statement is correct. When boosted, you need to open up the intake and exhaust which in turn will make more power. NA will probably have better power down low (but not enough to really notice) and fall flat on its face in higher RPM's due to airspeed through the intake runners. The more narrow the runners are, the faster the airspeed is through the runner. You open it up, the air slows down. You get what I'm saying right?
that sux
Jim at J&M wasnt gonna charge me much at all since he owes my dad a few favors. He also wasnt sure if it would do much to the VQ30 but it does mad help to the B and H series engines in hondas/acuras. thanks for the info deezo, I trust Jim alot and when he says "not sure" i thought id come ask you guys. He does alot of work on police cars uniformed and undercover.
Debo, It's actually the other way around.
Open up the ports, and low end would probably suffer but high end breathing might get better. Big ports = lower intake air velocity at low rpm. But should be able to flow more air at the higher rpm ranges.
Well, I'm thinking in terms of the VI vs USIM. On the low end of the RPM's the USIM has more power than the VI(USIM: larger diameter runner - VI: smaller diameter runner).
either way it ought to help, you just might not see the full potential of the modification until you go forced induction.
The main benefit while you're NA is that airflow will be signifigantly smoother, and while the diameter may be larger, the smoother airflow should make up in part for the loss in velocity. Smoother airflow means that the engine has to work less to pump air into the engine, less turbulence means that the air is there on the next cylinder stroke.
This sounds a lot like the tornado SC BS but it's different in that within the heads and the manifold, it's actually close enough to make a difference. You will most likely gain top end from this mod and lose a bit of low end. The VI is different in that it doesn't alter the runner diameter, but just the length.
I say do it, and go FI later
Originally posted by Chinkzilla
I just noticed u drive a 5th gen. Could this work with the variable intake manifold on the 2k's? The butterfly valve may not seal completely?
Originally posted by UMD_MaxSE
The length of the intake runner is varied... at lower RPMs, the longer intake runner is used, and at high RPMs the shorter runners are used.
install your VI yet? You know you want to....
Plus my wife is pregnant and the baby is due soon. They'll be taking most of my time for a little while.
5th gens intake manifold is made of a plastic/nylon resin anyways... I don't think you can port/polish that....
now that I know the IM is made of resin/plastic, I will talk to Jim and see what he thinks....
What im understanding and someone correct me if im wrong, i may loose a lil on the low end but maby gain on the high end especialy if I go SC or turbo. This MAY be barly noticable on a NA application.
If i had(will soon have) the supporting mods, Y&B pipes ect.. this may help a lil?
im still a lil confused about the IM, but i do wish we could port the head on the engine, polishing may help that a lil but porting may crack it(as far as I know)
NE way thanks for the help guys, if any one has more info please post.
One thing shouldn't be confused about port and polishing, it's good for boost. It doesn't do much for NA.
I could be wrong but I think he was LESS than impressed. Especially considering it cost him close to $400-$500
Originally posted by Mishmosh
Check the dyno section. I think Keven97SE had VERY impressive numbers with an extrude hone USIM before he went to MEVI...
I had an extrude honed intake manifold on my car prior to going to the variable intake. Based on my dyno results and SOTP reaction, the EH'd intake doesn't do a whole lot. What it does do it move the torque peaks at ~3300 and 4500 up a few hundred rpms and adds about 5 ftlbs to each of those peaks. Overall, the average torque/HP gain wasn't much at all. This upgrade does not offer a good HP/$ ratio. I belive that only if a Maxima is force-inducted would it really see a worthwhile benefit from a honed intake manifold.
agreed...
maxima297
Sep 30, 2015 03:32 PM
