BMW E36 Headlights(Need Help)
Old Mar 28, 2003 | 07:13 PM
Starchild2k3's Avatar
Yea im intrested i purchasing the 92-98 BMW E36 headlights for my 1992 Nissan Maxima gxe. I wanted to know everything you need to make the conversion. I know I need bulbs, but will it fit right into the slot where the stock headlight came from. It comes with a U.S. Spec wiring harness also, I just want to know what else I have to do before I really consider purchasing these headlights. Im up for all opinions, but mostly facts. Thank You
Old Mar 28, 2003 | 07:37 PM
«§»Craig B«§»'s Avatar
www.geocities.com/bmwconversion
Old Mar 28, 2003 | 09:10 PM
KaneTHS's Avatar
OOOhhhh Ahhhhh
I like these. I like these a lot. I might do this. Hmmm. LoL.
Old Mar 29, 2003 | 10:40 AM
kingrye's Avatar
i got it and dude its not all its made up to be. yes ive got better beam pattern and yes it looks unique, but youll know what i mean if u got them. dont buy the stock us e36's, buy imported projectors.
Old Mar 29, 2003 | 06:38 PM
jkmay01's Avatar
Lil 8
what is the difference between the two U.S. and Imported?
Old Mar 29, 2003 | 07:36 PM
kingrye's Avatar
there are differnt type of euro's they are all glass differnt projectors, better visability, differnt bulbs, look better, fit better ( more cutting Required),easyer to up grade, most us spec are going to be used if u want a deal,
Old Apr 1, 2003 | 11:22 AM
Taegost's Avatar
I am about to purchase a set of Euro-spec ZKW lights w/DDE conversion, and the person I'm going to purchase them from said they are slightly larger then the US-spec. Does anyone know if there would be a serious fitment issue, or would it just be a minor matter of more power tools?
Old Apr 1, 2003 | 01:55 PM
kingrye's Avatar
all right dude your going to have to cut metal no matter what do it right and use a die ginder with a very good cutting bit. i got my bit at a high end power tool store it is daul action it cuts and smooths with the same bit. dont use a dremal they suck. and it takes for ever just cut and try o fit, cut and try to fit, till it looks like how u want it. thats the best advice i can give to people want e36s
Old Apr 2, 2003 | 02:33 AM
ryochan's Avatar
okay.. this is really cool modification and I would really love to do it on my 92 Maxima SE.. Is it possible if I can hire mechanic to do it? Or it would be easy enough for me to do it? thanx
Old Apr 2, 2003 | 03:58 AM
Taegost's Avatar
That's what I figured, thanks for the input
Old Apr 2, 2003 | 05:40 AM
nubiannupe's Avatar
OG Maxima.org Member
Dude, there's absolutely NO reason for you to hire a mechanic to do this. Unless of course you WANT to waste money like that. I did it, and it only took half a day from my otherwise busy schedule. Heck, anyone that can cut paper with scissors, butt-connect a wire, or walk while chewing bubblegum can do this mod!
Just MY $0.02 worth...
Old Apr 2, 2003 | 07:18 AM
Mike92GXE's Avatar
Old Apr 2, 2003 | 11:11 AM
kingrye's Avatar
theres nothing you can screw up just be smart about it and use some amagination its not too hard
Old Apr 11, 2003 | 05:30 AM
pest2001's Avatar
can i run the e36 light and my stock harness or do i have to upgrade it and which wires are the high and low
Old Apr 11, 2003 | 05:46 AM
nubiannupe's Avatar
I know you just want to make sure you're doing this conversion right bro (if there's such a thing as "right" when putting BMW headlights on a Nissan...), and you may or may not get mad at me for saying this, but you obviously haven't read the 2nd post in this thread that Craig put up. But for your convenience, here ya go:
«§»Craig B«§» www.geocities.com/bmwconversion
I just followed the instructions on that page and had NO problems. And for the love of Pete, use a tester of some sort!
Old Apr 11, 2003 | 05:49 AM
DaBoxSE's Avatar
I suppose once you do this mod, there's no going back to stock without new headlight housings, right?
Old Apr 11, 2003 | 06:03 AM
Mike92GXE's Avatar
Of course you can go back, you just have to replace everything you modified with the stock parts.
Old Apr 11, 2003 | 06:47 AM
pest2001's Avatar
ive already been to that site but i just want to know which wire is high and which is low
Old Apr 11, 2003 | 06:56 AM
nubiannupe's Avatar
It's a matter of testing the wires. I CAN tell you, that the middle wire (which should be black) is the ground. After that, it's just a matter of turning on your low beams, putting one end of your test light (or DMM) to a ground point on the car, and the other end to the wire you want to test. If it lights up, then THAT wire is the low-beam wire. And I'm 99.99999% sure I don't have to tell you what the other wire does...
But if you REALLY need any extra assistance, let me know. I can probably walk you through each step if you want. PM me.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
