Buying an '85 Maxima soon, need help!
I found a 1985 Nissan Maxima with 270,000k (new clutch, transmission, 120,000k on a new engine) priced at $500 barely a block from my house, for sale by the original owner. The price is low, so I'm not going to bother taking it to my mechanic and spending $50 for an inspection, but one thing worried me: In sharp cornering the rear would make a humming noise (think "nnnnnnn"), as if something were rubbing. The seller said it was the rotors, but the problem didn't arise during breaking or light turning. So what could be wrong? How much might it cost to fix, if it's even a critical issue? The suspension components have never been replaced.
Other quirks: A bit mushy at accelerating from a roll (versus my old '83 SAAB 900 Turbo, which had a beautiful punch to it); the pedals are cramped, which makes it somewhat difficult to depress the clutch fully; the suspension doesn't exactly exhude confidence, though body roll is low.
I need transportation, even if it's not too great, but does this look like a decent buy? Could the humming from the rear become a more serious issue? Thanks!
PS. This may be a super-n00b question, but what are the major differences between the '85 and 86-88? Why does the performance parts list say only that items for the latter may work for the former?
Well, since there isn't too much stuff in the back, there aren't too many things to consider. I'd check the brakes first, the caliper might be seizing and rubbing up against the rotor. If that's the case, you'll have to rebuild or replace the caliper, which isn't too expensive.
I'd also check the wheel bearings, as that could be the source of the humming noise. Wheel bearings aren't too expensive either, I paid about $40 to do my rear left wheel. Another thing that it could be would be the fuel pump, it may be on its last leg. I'm not sure how much it is to replace, but I don't think that it's cheap. I'd also check the suspension components, though I've never heard of them making a humming noise before.
I have no idea what the difference between the '85 and the rest of the 2nd gens are. As far as I know, the '85 and '86 are slightly different than the '87 and '88, though it's mostly cosmetic differences.
-C-
-C-
-C-
-C-
Originally posted by electric!sheep
I'm probably going to buy it today, so bump for more opinions!
S
Good god. I got the car for $500, didn't take it to a mechanic beforehand, went in for a timing belt replacement and now have a $1200+ bill in repairs!
Work done:
- Rear bearings.
- Front axle boot.
- Distributor cap (original was cracked and corroded).
- Air filter (was filthy and in upside-down).
- Spark plugs.
- Cam seal (or cover?).
- Timing belt.
- Some valve or other.
- Rear breaks.
Oh well, I guess it all adds up to the approximate Blue Book value ($1,700) of an '85 in good running condition. Then again, the front left strut will need work at some point, as will the throw-out bearing. Yay.
Work done:
- Rear bearings.
- Front axle boot.
- Spark plugs.
- Timing belt.
- Rear breaks.
Geez dude...that's quite a bit of money...but will all that is done...that sounds pretty close to what it would cost to replace all that. Either way...now that you have that money in it, don't let go of it.
I can say one thing though...270k maxima is very rare thing to have.
S
S
Work done:
- Rear bearings.
- Front axle boot.
- Spark plugs.
- Timing belt.
- Rear breaks.
Work done:
- Rear bearings.
- Front axle boot.
- Spark plugs.
- Timing belt.
- Rear breaks.
kjlouis
Nov 24, 2018 06:09 AM
ah2002
Mar 9, 2016 01:42 PM
MikesChevelle
Aug 6, 2015 11:36 AM
