Belt jumped a rib...
Old Apr 2, 2003 | 05:13 AM
ejj's Avatar
ejj
Heard a strange noise this morning on my way to work...opened the hood when I got here and sure enough the belt was off by a rib. The belt seems fine, and is still intact.
Two questions...
1) Is it ok to drive the car home after work? Its about 5 miles. I don't really want to work on the car in my company parking lot if I don't have to.
2) Could it simply be because the belt was loose? I left it loose on purpose to make sure that everything was happy...Could it being too loose allow it to hop off?
Old Apr 2, 2003 | 05:44 AM
delio's Avatar
Re: Belt jumped a rib...
Don't boost, get it home, I wouldn't want to work on it in my parking lot either.
Two questions...
Old Apr 2, 2003 | 06:41 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Check belt alignment... see [maxi-overdose]'s threads/posts regarding alignment problems.
Old Apr 2, 2003 | 09:46 AM
BlackCat's Avatar
RIP '98 Maxima SE
Don't drive around with the belt like that!
The pulley edge will cut off the rib and that bit of loose rubber will be whipping against the hood liner creating a hole.
Old Apr 2, 2003 | 06:50 PM
ejj's Avatar
ejj
Thanks guys. I got home with no problems. The belt has lost a rib, but for now I left it on as I don't have time to change it tonight. The belt was obviously looser than before (as is normal with belts). I left the belt on loose to begin with to make sure there were no alignment problems, but now I think it may have jumped because of the lack of tension.
Sound reasonable?
Old Apr 2, 2003 | 08:56 PM
delio's Avatar
Sound reasonable?
Very reasonable, that thing gets humming pretty good, at high RPM, good tension is a must.
Old Apr 3, 2003 | 04:36 AM
ejj's Avatar
ejj
Any damage using a belt with 5 ribs for a while? I understand that it will be more prone to slip...but beyond that?
Old Apr 3, 2003 | 05:52 AM
delio's Avatar
IMHO no, as long as you have good tension
Old Apr 3, 2003 | 05:55 AM
ejj's Avatar
ejj
Thanks for all the help.
markevans999
Oct 25, 2015 08:27 AM
Need help
23
Oct 2, 2015 08:56 AM
homewrecker
Sep 24, 2015 07:01 PM
markevans999
Sep 10, 2015 04:29 PM
trungg86
Sep 4, 2015 04:58 AM
