port & polish
Re: port & polish
Originally posted by sand2kmax
anyone in here perform a port and polish? what are the expected gains on a 3.0? how tough is it?
Originally posted by maxman00
I don't think that you can port and polish a VI manifold. This could be done to a 4th gen, and I believe there are decent gains.
Originally posted by sloppymax
i didnt even think about not being able to do it on the composite (plastic) manifold. just out of curiousity does anyone else have an idea if its possible?
I didn't realize it was a plastic composite.
In any event, unless Nissan made really nice heads, I would think there would be decent gains to be had by smoothing corners on intake and exhaust, as well as mirror finishing the exhaust side.
I was wondering if anyone has actually done this and dyno'ed to get an idea of the gains.
American cars typically gain a lot from P&P work on the heads, but I'm not sure if that is just because they are so bad from the factory.
from what i found p&p on the heads are good gains if you have the right shop do it. other than that the usual upgrades are allways nice gains CAI, Y PIPE, CATBACK EXHAUST, CAMS, ECU UPGRADE, for me i noticed a nice gain from the ypipe an exhaust.
Must important thing would be to be sure the ports are aligned or matched and that any obstructions, flashing, casting globs are eliminated. You wanna concentrate on the velocity not boring the hell out of it... or enlarging it,... just cleaning it up some then, roughen it up some to increase the fuel atomization! It will make your throttle extremely crisp and more responsive!
I definitely know you can port match a '00 VI. Just not the upper composite manifold. The lower manifold, intake ports on the heads, and exhaust ports on the heads can definitely be ported.
BUT, when i removed my LIM, i held the gasket to the intake ports on the heads, there was a very very slight difference in bore size, some if any.
I was going to attempt it, but after seeing that, just decided to delete the swirl valves and call it a day ahah.
Earlier engine suffer from poor port alignment but these newly designed engines which are CAD designed have excellent port alignment and fitment. You'll have the remove the heads to get to the real crap!
The upper to throttle-body mismatch on '00vi's is absolutely horrible. Just estimating theres 5-10 hp right there, allthough I haven't had the chance to do a before and after dyno, but I will in the future.
followthadollar
Sep 23, 2015 08:31 PM
