engine light..little pain in the a**
Old Jan 18, 2001 | 04:35 PM
wicked1044's Avatar
today i received a message from my car. the check engine light came on.. so i got under the seat and did the self-check. it stated the problem is 0707. i looked around and web sites say it means rear heated 02 sensor.(or rear 02 sensor) what does that mean?? also if i reset the light will the light come back on if the problem persists??? thank you...
Old Jan 18, 2001 | 04:44 PM
vbxmaxima's Avatar
Yes,
If the rear oxygen (O2) sensor is busted, the check engine light will return after you reset it (cause the problem still exists - so the ecu will tell you about it).
The rear O2 sensor on my 96 is located on the rear portion of the catalytic converter.
O2 sensors tell the engine if you are running rich or lean.
The rear will also provide indication of the health of your catalytic converter.
O2 sensors cost about $100.
Old Jan 18, 2001 | 04:50 PM
wicked1044's Avatar
thanks.. so should i reset it and see if it comes back on? you have a nice site there buddy.
Old Jan 18, 2001 | 06:04 PM
ejj's Avatar
ejj
Originally posted by vbxmaxima
Yes,
Not necesscarly. Depending on the exhaust mods that you have done it might not be busted. I have an RT Cat, and within a week of installing the cat I got the same code as you. Now, when I reset the light it comes back on every week or so.
I guess this is a common problem for people with a RT Cat ( something about the cat element being closer to the sensor thus changing exhaust properties when it gets to the sensor ).
Old Jan 18, 2001 | 06:21 PM
Kenneth's Avatar
OG :)
doesn't matter, the car will not be affected.
measure the health of the cat which would be done with any state inspection
Old Jan 18, 2001 | 06:32 PM
Chunger's Avatar
My other car is a Hybrid
RT cat shouldn't kick out the error code
Originally posted by ejj5875
I guess this is a common problem for people with a RT Cat ( something about the cat element being closer to the sensor thus changing exhaust properties when it gets to the sensor ). [/I]
I don't think putting in a properly functioning catalytic should trigger this error. Mine didn't (still doesn't). Like vbxmaxima stated...it compares the values between the signals before vs. after the cat... if all is working as it should... the signals should be different obviously.
Old Jan 18, 2001 | 06:35 PM
ejj's Avatar
ejj
Re: RT cat shouldn't kick out the error code
I don't think putting in a properly functioning catalytic should trigger this error. Mine didn't (still doesn't). Like vbxmaxima stated...it compares the values between the signals before vs. after the cat... if all is working as it should... the signals should be different obviously. [/I]
Hmm. I've heard of lots of other having this problem. I remember that Biomax had this...and a few other people that I can't remember.
I know its the cat...because putting the stock one on solves the problem.
I haven't had my emissions tested since I got the car...I will when I get inspected in March.
Old Jan 18, 2001 | 11:02 PM
vbxmaxima's Avatar
It certainly wouldn't hurt to try. Check out the wires too.
The check engine light code encompasses both the unit and its associated wires/cables/connectors.
Just last week my light came on.
Said it was the engine coolant temperature sensor.
-Long story short: the connector had just gone loose. Didn't need a new sensor.
BTW AWESOME engine compartment you got there, wicked!
Old Jan 18, 2001 | 11:12 PM
vbxmaxima's Avatar
By the way Wicked,
In case you wanted to see where the rear O2 sensor is at,
(at least for a 4th gen) look here:
http://vbxmaxima.8m.com/shifter.html
In step 7, you can see the O2 sensor between the green and red arrows, along with the wires leading to it.
Good Luck!
Old Jan 19, 2001 | 06:20 AM
natewall's Avatar
Now here's some GOOD news. After buying my '96 Max used, I did some research on dealer recalls and the only one of any significance was a campaign to replace (all 3?) oxygen sensors w/ improved ones, (regardless of mileage?) AT ABSOLUTELY NO COST. My "check engine light" never came on, but the dealer service rep said it was just a matter of time. Any Nissan dealer will do the service. CALL THE NEAREST NISSAN DEALER ASAP! About a month after the service was done, I got a letter in the mail mentioning the recall and asking me to bring the car in, but don't count on being contacted by Nissan.
_Nate Wall
shilov
Feb 19, 2024 09:40 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
16_SR
Sep 9, 2015 07:14 PM
