Bushings
Old Apr 16, 2003 | 05:46 PM
Hurley42385's Avatar
Bushings
I had to change my brakes and turn my rotors and i noticed what i believe to be the rubber bushings that are connected to the power steering assembly...I'm really not sure what it is connected to but i think thats what it is. anyway, the bushings are ripped to hell so i was wondering about the polyurethane bushings people replace their bushings with. sorry for not knowing what the hell i'm talking about but i hope yall understand.. thanks for any help.
p.s. its a slender metal shaft that goes into a rubber boot
Kenny
Old Apr 16, 2003 | 08:15 PM
scott92282's Avatar
If it is attached to the hub assembly, then it is the CV boot/axle. Once the boot is torn, then the axle will start to make a grinding sound around turns and/or acceleration. Replace the axle. Once the sound comes, you don't have too much longer.
Old Apr 17, 2003 | 09:23 AM
its not connected to the center of the hub i believe whenever you turn the steering wheel this is the rod that turns the wheel.
Old Apr 17, 2003 | 09:31 AM
DanNY's Avatar
Ad·min·is·tra·tor
either you're talking about the tie rod.
the joint that connects the steering rack to the wheel hub/knuckle.
OR
the boots on the steering rack. looks like a accordian or something like that?
Old Apr 17, 2003 | 09:33 AM
Michael's Avatar
Back in a 3rd Gen.
then those are not bushings. They are tie rod boots (or bellows) if it is torn then I would go ahead and replace the inner tie rod (what the boot covers) in case there is grit in there and replace the boot.
Starrider
Dec 18, 2015 04:43 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
ColdCananda
Sep 20, 2015 10:45 PM
